Inverto Ultra Black lnb feedhorn
samoloko
1.8 PFA
EU
There are many that tweaked Inverto Ultra Black lnbs to work with parabola
Would you please give me Information about Inverto Ultra Black lnb feedhorn - Single and Dual
I like to know precisely Inner and outer diameter of feedhorn
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I've made new feedhorn for IBU, but on attached drawing you can see precise dimensions of original IBU feedhorn. Maybe that helps.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Would adding this help us Astra 2 fringe dwellers?
RimaNTSS
N-E from Riga
It helped for me, so do not see restrictions for others.
samoloko
1.8 PFA
EU
Rima,
great as always
THANK you
did you measure Inner diameter of Inverto Ultra Black single precisely
from my measurements of Inverto Ultra Black Dual Inner diameter Is 18,2 mm
RimaNTSS
N-E from Riga
I know that it is not so easy to measure precisely inner diameter. Only very special tools can do that. So, 18 or 18.2 both right enough.
By defining the outer diameter you are restricting the feed to accept more upper band at the expense of lower band.
You can achieve similar results by trying a few folds of food can (or drink can), carefully inserted (oooerrrr ) to not disrupt the usual signals.
