C-Band Extended
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Sorry John, can´t lock atm. (bad aligned...) :rolleyes:
Anonymous_1
My scan (2.40m)
Love nature 4K is just an other loop demo by SES ...(HDR)
dreamsat
germany
may scan today at 30,5° East
regards dreamsat
dreamsat
germany
scan 40,5° West
regards dreamsat
dreamsat
germany
40,5° West 4770 L 50000 16APSK
2 dB are missing for a lock
regards dreamsat
regards dreamsat
Hi dreamsat,
Are you capturing these off your 3.7mtr ?.
Can you tell us what make / model number of the extended C-band lnb in use please.
Thanks.
dreamsat
germany
yes witht 3,7m :Y
i have a Norsat LNB
regards dreamsat
dreamsat
germany
a good reception at C-Ext. 40,5 W
Anonymous_1
Here is my scans with 2.40m .
Lexzie
TBS 5925 USB-tuner
The Netherlands
Why is there no LNB(F) for the whole c-band?
Just like there's no for Ka band.
At least not for reasonable prices... :(
Physics. It is not (at the moment....)possible to provide a decent level of signal across a bandwidth wider than the general parameter of the band being received. The fixed dimension of the feed and the first components in the detector circuit will always be a compromise. We are waiting a new generation of front ends that can be adjusted both electrically and mechanically to tune more efficiently at a wider range of frequencies.
Anonymous_1
65W (2.4m)
4770 V finally locked but empty since Love nature has moved @ 43°W
65 West,
4566 H on the analyser here but only at 5.5 dB with no lock at the moment.
