Satlink WS6906 upgrade (mine)
Hello can someone give me a working link to The software upgrade
Have you tried the Satlink site? I think you have to pay to get a working link..
Piltdownpaul
No.1 Spike Milligan Fan
Surprisingly my 6906 still works!!!!
Piltdownpaul
have you find original firmware for ws6906 and have anyone some channel editor for it ?
For the newbies to the forum, you need to understand that there are TWO VERY DIFFERENT versions of the 6906, but Paul's f/w upgrade applies ONLY to the early version - and if you have the later version (which you probably do have if you bought it within the last 3 years or so) then using the early version will cause a major issue by "locking it", but that can be cleared by doing a Factory Reset.
This pdf shows the front panels of the Early and Late versions of the 6906
Dropbox - WS6906 buttons - Early & Late models.pdf
I ran into the same issue myself, but finally solved it earlier this year - and then created a replacement f/w upgrade bin file which does work on the later version, and mentioned that in another thread.
However, for simplicity, I am repeating the critical info from that thread here, as follows: The bin file that I created after I reset my 6906 to remove the "Lock" light, and then entered transponders on the strongest beams for the UK a number of European satellites (In Jan 2018) is here:
Dropbox - 2018-01-04 Data Dump 3.bin
Hopefully, that will allow a locked late-version 6906 to be reset and to load that reasonably current satellite and transponder database.
beano2
sunrat sr4 hd se
uk
hi
jeallen01 just like to say thanks as that has got my meter working
satmanbasil
Archived Member
Visit site
uk
Hi guys
I have bought the ws-6906 meter and im able to download to my pc the bin file but cannot find
an editor that coverts this into a readable file that can be edit do any of you guys know what can be used
to do so or am I stuck with downloaded bin files that cannot be edited
regards
Sorry, but, I can't help with that aspect.
Dia M2030
Yahsat
Denmark
Hallo jeallen01
can you please resend the bin file the link dos not work for me
Hallo jeallen01
Sent you a PM with the zipped version of the .bin file as I don't have to check out/sort the Dropbox link.
To avoid any further issues with downloading my 2018 data dump .bin file from Dropbox, here is the zipped file as sent to M2030, and so it should be easily accessible to anyone else that might need it.
  • 2018-01-04 Data Dump 3.zip
mambo5
forgot password
kenya
hey guys any help to remove forgotten password of my ws6906
Which version do you have ?
Usufi
Middle east
Manama
Hello brother do you have satlink loader ? If so please send me a link
See Post Number (#)52
Usufi
Middle east
Manama
Please can I get middle east tp.bin files
I don't have those.
Unless someone in the Middle East can provide them (Unfortunately for you, none of the people who created their own lists based on mine have then come back to this forum and posted Zipped files with their new bin files), you will have to do what most people have done in similar circumstances - which is to edit the one I pointed to above by loading it up into your 6906, delete the satellites you don't want and add those that you do, and then adding the appropriate transponders and channels (then resave as a new bin file for the future.)
smugdruggler
Freesat using 1 meter dish and dual LNB
Dell Laptop
Surrey Berkshire border
I too would like the loader if you have it :-)
