Dear it's Ku BandC Band, or Ku Band?
Thx. dear .. but all the charts I've found down ends with 32 db with assumption the lnb is 0.6 or more ... therefore I asked what about the sizes if the inb is 0.2 is there any chart related to that number ??From Baghdad you will need a very big dish,
38 dBW = a dish size of 190-240 cm so for 15 dBW you will need something over 500cm.
thanks very much .. I've tried "Satbeams" . unfortunately that details you mentioned didn't appear in fringe areasYou can also go to "satbeams.com" and select the satellite your trying for, then click on the little green globe at the right of the listing, this will bring up a foot print map for that satellite, if you then click on your location, (you can zoom in)(you may need to select the correct beam first) it will give you an estimated dish size needed for a stable picture, at your location for that bird.
I dont know .. but what about that ??A change of noise figure is going to make virtually no difference.
there is an extra 180 cm for the same 35 dbw with the difference of lnb low noise , I dunno if I got it right or not !
What satellite(s) are you trying for?? If its above your visible horizon you should be able to get something if it's a hemisphere wide beam, but a spot beam may be out of the question.thanks very much .. I've tried "Satbeams" . unfortunately that details you mentioned didn't appear in fringe areas![]()
