Advice Needed anyone have Toroidal T90 ?
mirrors
starsat sr 4040 hd
Baghdad
hi there
I just need a help from any Toroidal T90 owner .. I need to know the dimensions of it , please .
depth of main dish ? negative depth of the secondary reflector ? distance between dish & sec. reflector etc. if there is more will be better
will be glad to hear from anyone :):rolleyes:
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Not got one myself but this attached may help.......good luck.
Be safe.:Y
  • Toroidal T90 772389-wavefrontier_datenblatt_nologo.pdf
Main reflector
Height
96.7 cm (38.1 in.)
Width
108.6 cm (42.8 in.)
Sub reflector
Height
36.1 cm (14.2 in.)
Width
83.6 cm (32.9 in.)
Net Weight
14.1 kg (31.0 lbs)
mirrors
starsat sr 4040 hd
Baghdad
Main reflector
Height
96.7 cm (38.1 in.)
Width
108.6 cm (42.8 in.)
Sub reflector
Height
36.1 cm (14.2 in.)
Width
83.6 cm (32.9 in.)
Net Weight
14.1 kg (31.0 lbs)
thank you very much , can you measure the depths for both main dish and sub reflector . it is exactly what I want ?
regards
The four I have installed are on walls on clients' houses.
The sub is about 16cm - but bear in mind it's a very complex shape.
Main dish is about 9cm without any of the mounting brackets.
mirrors
starsat sr 4040 hd
Baghdad
thx dear .. so appreciate it
