Decided to have a go at ADS-B
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Finally got around to having a bash at this, dug out an old RTL-SDR Dongle, put the FR24 Image on a SD card and popped it in to a spare Raspberry Pi2 I had here.
For the Aerial I built a simple "Cantenna" It's thrown up on a painters pole using some WF100, just trying it out.
Used a Aldi New Potato Tin, drilled a hole and soldered a F Type coupler, poked all the bits out of the middle so I am just left with a thread either side:
Got some WF100 and stripped it back, fitted a F Type as normal but leaving the dielectric over the centre core, trimmed to 69mm:
Used amalgamating tape on the F Type, then fitted the it to the can using a F Type slim tool;
Using some "Liquid Tape" I sealed up any holes on top of the "Cantenna"
Using a Dremel I cut the tin to 69mm, measuring from the top of the thread:
Using some hot melt glue I mounted the whole thing in a 100 Blank CDR Case:
Lashed it up on top of a telescopic painters pole to test:
Seems to be working :)
Looking good - once you get Virtual Radar Server running your jaggies will look impressive :D
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
If you have set your location you can set range rings in the main prog & then click on menu on the browser then receiver range to get something like this:
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Thanks, just set that up :)
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Just 3D printed a bracket so I can fix it to my Telescopic Painters pole, INOX/Stainless screws were used :)
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
A nice variation on the usual colinears. Looks good too :)
Thank you :)
I will build a 1/2 wave and a 5/8th as well, see how they perform.
Just had to get something up today to get receiving, hadn't had chance to get around to it.
