Es'hail 2 band plan and guidelines
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Anyone got any thoughts as to what size dish is going to be needed for the downlink in NW Europe?
Will probably be a Yagi opposed to a dish.
12/13cm uplinking requires quite a bit of gain and directionability from a yagi so has to be very well constructed.
It might be preferred in Europe but in the US an ex-TVRO mesh antenna would be the cheapest way to get a signal out there.
Both types will require a similar dual axis tracking system, but with the Yagi array there is the added combining and phase distribution.
Both types will require a similar dual axis tracking system.
Agreed, but a quite simple Yagi is all that will be needed for the downlink.
Ordered some cheap (£3ish) PLL LNB's to mess around with, 25MHz crystal inside should work fine for this.
Might put a 24/23MHz crystal on one of the form some 10GHz DATV stuff.
Cheap PLL LNB's turned up, work well in 10GHz band :)
Once you get it working & pics/ tv from Es'hail 2 will you write up a how to please? :)
Absolutely, currently building a DATV transmitter for a few different bands as well, it's based on the Portsdown project, hopefully one day
I will be able to send some video up to Es'hail 2
Was using the GPIO pins on the Pi earlier to generate RF and was receiving it on my SDR! crazy what a Pi can do.
It would be mega cool if you sent the forum logo & we couild watch it :D :-rofl2
That Portdown transmitter looks fascinating. :)
Install the Portsdown software on a Pi, put a LCD on top (Waveshare 3.5") and have a play, plug in a RTL-SDR and receive DATV if there is any in your area.
Bugger all I would imagine - there are only 2 amateur radio clubs in the area in a 30 mile radius. This is a very low population area - the entire population of the Borders is only about 130k & the 2 reasonable size towns (Galashiels & Hawick) are both less than 20k
You can transmit/receive across the room with just 2 Pi's if you're bored, look at this. Not me by the way!
Probably the easiest way to get a TX is to use DATV-Express with a LimeSDR or ADALM_PLUTO. The latter was £70 +VAT from Mouser but has limited bandwidth due to USB2. If it's for Es'hail 2 then 2Ms/s is the plenty. Using a LimeMini I could get about 4Ms/s on an i3 laptop but you should get more by using a better PC.
About - DATV-Express digital-ATV project
I've used the TBS6983/6903 down to 125ks/s but they don't blind scan very well at that symbol rate.
Im considering the Lime SDR Mini as I don't need below 10MHz
My friend has a DATV Express, but I think he wishes now he'd gone down the Lime route.
