OCTAGON SF8008 E2 4K UHD
OK I have loaded two identical VIX images one in the SF8008 and one in the Edision nino pro and tested out the new blindscan for Ka on 19E, the nino has no problem finding the Newsnet tranponder, but the SF8008 returns nothing. This was also the same result when I had open ATV loaded in the SF8008 last night...
How about if you do a regular enigma scan with the SF8008? Does it find the channels ok?
Can you receive 30 west? How do they compare 11496 H?
Regular scans on the SF8008 are fine.
Both receivers receive the transponder 11496 on 30W but there is break up with the Octagon, this has been reported before, the nino is rock solid!
Anyway thanks for testing. I'm glad to know it is not the plugin that is the problem. I've got an Edision OS Nino Pro here too and the tuner is outstanding.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Muta@nt HD60 is available in Europe, seems very similar to the SF8008
CPU: ARM Cortex A53 Quad Core Prossesor.
Hisilicon H13798MV200 Chip.
Quadcore 15,000 DMIPS 4x1.6Ghz.
1x DVB-S2X tuner.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
different factory
hd60 no intern wifi, no 1gbit LAN , only 100mbit lan, no ct2 tuner .. pls check all specs when you compare
It's still a similar box to compare, the key thing for most people on here is the Sat Tuner, Blindscan, CPU etc.
And Mutant deliver what they promise, driver support is better.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
OK lets make this explicitly clear. Just so there is no misunderstandings - anyone making a nuisance of themselves asking for help getting Albertis working will be thrown off the forum with no further warnings. Our staff have removed several such posts.
If you cant get it working yourself then you do without.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
sf4008 different factory, cheating octagon, is not octagon misstake, korean misstake , 8008 different factory, much better supporting, sure yo ucan think what you want, its up to you
The SF4008 IS the mistake of Octagon because the name "Octagon" is written on the front of the SF4008. The factory you want to blame Does Not have their name written on the SF4008. It is time to quit blaming others. Own up to your mistake and move on.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
We are not talking about Xtrend, GI innovation or others. We are talking about Octagon.
You need the own the mistakes of your receivers.
No matter if it is the SF4008, SF8008, or a future model number. These receivers have the name Octagon on the front of them, so the responsibility of how these receivers work can only be Octagon.
Laser
Are there any more software updates for 8008 planned?
samoloko
1.8 PFA
EU
comparing SF4008 to SF8008 without having both box, I see that first box look much solid and with better build quality
apart from blind scan what Is wrong with SF4008 - for Instance does anyone compare tuner sensitivity SF4008, SF8008, Edison primo pro both DVB S2X and DVB T. Is there differences In receiving multistream and T2I channels
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
TBH, I don't think there was much wrong with the SF4008, people always bemoaning the fact there was no Blindscan, but even if there had been, it would have been next to useless as it is on most E2 boxes. It's only recently that E2 scans have improved, for example the Edision stands out in that regard. It does seem Octagon were let down badly from the their hardware supplier with failed promises. Lets hope the new supplier is better.
Blindscan in the SF8008 is now fixed for KA band. Heuvos has been working with a few of us on here to improve it and few other things even more.
