Advice Needed New multistream receiver
Lexzie
TBS 5925 USB-tuner
The Netherlands
I have been playing around with a VU+ Zero 4k for a while, but still missing features I'd like to have.
I know some are impossible to get on a settopbox, some features must be possible.
Off course DVB-S2X, MIS(multistream), PLS, H.265, hbbTV. That has the VU+ allready.
-Low symbolrate, so below 1000.
-A working blindscan function (DVB-S/S2).
-A remote control that will not be interfered with my plasma TV.
-possibility to connect USB tuners
Preferable:
-easier T2-MI reception
-transcoding feature
-more (pluggable) tuners
-Capable of running OpenPLi
Probably impossible:
-4:2:2 reception
-Other exotic signals capable, if any?
Can anyone confirm one or more of these features working on their receiver?
Like Mut@nt HD51 4k, Gigablue, Octagon (SF5008?)/SF8008, Zgemma?, other VU+ receivers?
I believe a Silabs Si2166 tuner is best for blindscan?
Lexzie
TBS 5925 USB-tuner
The Netherlands
No one can give me some advise or share their experience?
4:2:2 is easy if you can use the webif relay via the network - you just stream it to vlc player on a computer - I used to do that 10 years ago on my old 7020
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
i got a mutant 51 just for openpli & t2mi replaced my vu solo2.
You can still use your old vu remote aswell just change the control in input devices!
Use to have Octogan sf4008 but too hard to swap images so gave it away..
stonesatellite
Vu+ Duo 4K SE (2x DVB-S2X) (2x Xbox One USB tuners (1x DVB-C & 1x DVB-T2) (1x Nooelec NESDR Nano 2+ USB RTL-SDR tuner)
Octagon SF8008 (2x DVB-S2X)
Mut@nt HD51 (2x 2x DVB-S2X)
Triax TD110
Sky zone 1 minidish
Inverto Black Ultra Twin LNB
Alsat Superior Dark Motor
Onkyo TX-SR605
6x Bose Acoustimass/Lifestyle double speakers
Stone, Staffordshire
im using a Mut@nt HD51 cant rate it enough, handles multistream & 4K fine. using an original Zgemma remote i picked up cheaply from eBay much better then the naff remote that it comes with
Lexzie
TBS 5925 USB-tuner
The Netherlands
Anyone experience with Dreambox DM920?
Im taking my HD51 out of service. The remote is totally crap & I still cant get on with the abomination that is the E2 s/w. Im going back to another TM5402 & put up with its quirks.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
replace the remote with a better replacement, thats what iv done. what is it that you dont like about Enigma 2 ?
Ive just never got on with E2 ever since I first encountered it on the Vu+ Duo. I find the operations on it over complicated and often illogical.
When the Duo died I took great delight in throwing it very hard into the electronics recycling bin up at the local council yard :-rofl2
edbe
Eygelshoven NL
anyone already use the gigablue trio k?
