Es’hail 2 25.5e
it plan launch first may falcon roket
old doc from 2017 beacon
2018-08-end NET F9 . S Es'hail 2 GTO ~3k C-40
will be launch in November
NET Nov. 15 from KSC's pad 39A. 1345 to 1800 ET (1845 to 2300 UTC).
the launch will be tonight
Narrowband Linear transponder
2400.050 - 2400.300 MHz Uplink
10489.550 - 10489.800 MHz Downlink
Wideband digital transponder
2401.500 - 2409.500 MHz Uplink
10491.000 - 10499.000 MHz Downlink
Equipment requirements:
Es'Hail-2 Geostationary P4-A Transponder Frequencies
Es’Hail-2 Geostationary P4-A Transponder Frequencies
X-Band 10 GHz Downlink:
– 89 cm dishes in rainy areas at EOC like Brazil or Thailand
– 60 cm around coverage peak
– 75 cm dishes at peak -2dB
– NB: linear vertical polarisation
– WB: linear horizontal polarisation
S-Band 2.4 GHz NB-Uplink:
– narrow band modes like SSB, CW
– 5W nominal Uplink power (22.5 dBi antenna gain, 75cm dish)
– RHCP polarisation
S-Band 2.4 GHz WB-Uplink (DATV):
– wide band modes, DVB-S2
– peak EIRP of 53 dBW (2.4m dish and 100W) required
– RHCP polarisation
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
So excited now!!
It is about 28°E, moving to west... Telemetry frequency 10756,00 RHCP.
So excited now!!
The amatuer tv payloads wont be activated until after the commercial payloads have started in service. Its likely to be early next year before they go on air.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I'm aware of that, but it's still exciting and looking forward to receiving any signals from it, plenty of time to start working on projects for it too :)
Im holding my Fracc Penta back for this project - Im l;ooking forward to the challenge of receiving amateur tv off it :)
aceb
Prof Tuner 7301 /
Sussex
What's required for the 3CM TV downlink? I see the Octagon optima PLL LNB is recommended with good performance at 10.5GHz but what modifications or tricks are required to get a sat tuner to receive that low?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I've been testing a PLL LNB, trying to keep it quiet as they are dirt cheap and once everyone knows they will sell out, can discuss it on PM though.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
s-band
Essex
The Octagon OSLO with 25MHz xtal works Ok down to 10.368GHz with some roll off with ~1.6dB NF vs 1dB >10.7G (real dB not marketing ones). It's easy to feed an external 25MHz ref, a search should find links. For TV, a TBS6983/6903 etc will go down to 250MHz, just modify streamreader.ini An Inverto Ka LNB Band B To Band A Mod - SatsUK
You only need to change IF start/stop, my other changes were for Ka & X bands.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
The later OSLO's are 27MHz and the price is going up on those alone.
Interesting regarding the TBS devices.
I wonder what the lowest most E2 boxes will tune down to.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Sorry made a typo on this and edit timed out, the latest OSLO are 25MHz, some are 27MHz its pot luck what you get and some might not even be PLL.
