s-band
Essex
The back plate on that one looks better than many (inc mine). A decent price and well worth saving. My 1.5 IRTE reflector fixings were seized. I used a mole grip on the heads, a spanner on the nuts and sheared the bolts. I then replaced each in turn with new stainless bolts so I could remove the reflector in a controlled manner. Care has to be taken not to get close to the reflector with the mole grip.
Angle grinder is one of my favorite tools, so, I would grind off all the "hard" nuts&bolts and save the time of one trip to the site. :Y
Not the feed assembly I hope.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Feed assembly can be thrown in the car trunk as it is. But, if needed I do not see difficulties to angle-grind any bolt or nut, including those from feed assembly. But, TBH, on particular antenna I do not see any "hard" nuts&bolts which could not be unscrewed in normal way.
nelson_b
Contributor
Yes, its been listed a few times.
Very tempting with what you get for the starting bid, that's of course if there is not a bidding war!
A twin for your existing 1.8m, they would make a nice pair, one for C, one for Ku.
Told the bride that....not the usual response....I plied her with wine!
aceb
Prof Tuner 7301 /
Sussex
Here's a bargain. once you've bought all the steel plate, stainless nuts and bolts, some threaded rod and paint, then spent a couple of days fabricating and weather proofing it. :-lmao
Satellite Polar mount | eBay
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Easy fix. Mine was on par or worse, at least it has bearings.
That is very badly corroded.
If the seller can't spell correctly what do they expect ?
