OCTAGON SF8008 E2 4K UHD
Whats the picture quality like on this ,especially SD ?
I've tried a load of receivers since the Alien 2 which was SH4 based and the picture quality on all of them has been inferior.
Even the Mutant HD51 which is Arm based and I'm currently using isn't much better than standard Mips receivers in the picture quality department.
my opinion (because also equipment depend as Television etc)
sd quality better then mips, but still i guess ARM bcm sd quality better then ARM huawei hisilicon ,
but hisilicon is new, may they can make better ,
Cheers ,I will stick with the Mutant HD51 for the time being so.
Hopefully the hisilicon might offer better picture quality down the line ,once the drivers improve.
TBH, I don't think there was much wrong with the SF4008, people always bemoaning the fact there was no Blindscan, but even if there had been, it would have been next to useless as it is on most E2 boxes. It's only recently that E2 scans have improved, for example the Edision stands out in that regard. It does seem Octagon were let down badly from the their hardware supplier with failed promises. Lets hope the new supplier is better.
Yes, SF4008 didn't have a blindscan driver available. Maybe there is still one in the pipeline. But the SF4008 was well ahead of the curve. First receiver out there with MIS/PLS S2X support. And yes the OS Nino Pro has an exceptional tuner for blindscan but very lacking in other areas compared to the SF8008, e.g. Kodi and Stalker which for the typical user these days are much more important than tuner sensitivity, after all this is a DTH receiver.
Owners of the SF4008 were treated to quite a few things that were not nice. Promises of blindscan were always advertised, and other things were broken when Kodi was added. You never knew what to expect during driver updates. One driver update caused boxes to bootloop. Some boxes were were useless after the bootloop issue because loading the bootloader (bolt.bin) was supposed to be a solution.
These issues have been posted at Octagon's website for a year and probably will always be ToDo's. (More issues have been reported.)
Hello together
Open Todos - Open Todos
- 2160p audio issue
- RAM memory issue
- Blindscan
these points are open and are under construction. Please do not post every day again!
these points are open and we are working on it. Pls do not post every day the same issues!
The SF4008 is an Octagon product. The defects and problems of the SF4008 belong to Octagon. No one is working on the SF4008 to fix the issues, yet Octagon claims they will be fixed.
Hopefully the SF8008 will fair better. We will see...
Octagon SF8008 hat im Test mit "sehr gut" überzeugt
von: Patrick Büttgen
In der Dezemberausgabe hat das Sat-Fachmagazin Digitalfernsehen den Octagon SF8008 ausgiebig auf Herz und Nieren geprüft. Das Testergebnis „sehr gut“ bestätigt den kommerziellen Erfolg des zweiten UHD/4K-Receivers von Octagon. Womit der Combo-Receiver im Test gepunktet hat und mit welchen Features er die Redaktion im Detail überzeugen konnte, erfahren Sie in diesem Blogartikel.
Zum Beitrag:
https://www.satking.de/octagon-sf8008-test
@Octagon-Germany
Mod. Note
Thank you but, as previously advised, we are predominantly an English Language Forum, so please ensure such Posts are accompanied by a Translated text.
Just to help out.....
Octagon SF8008 has convinced in the test with "very good"
In the December issue, the satellite magazine Digital TV has put the Octagon SF8008 through its paces extensively. The test result "very good" confirms the commercial success of the second UHD / 4K receiver from Octagon. What the combo receiver scored in the test and with which features he was able to convince the editors in detail, you will learn in this blog article.
Nach Treiber Update 05.12.2018 (after Update)
- SNR % dB value fixed. (Signalanzeige)
- Add Vtuner atsc support.
- Fix snr max db value.
- SAT>IP Client (SATIP) Support add. (Streaming / Multiroom)
- USB Dongles (V-Tuner) Support add. (Virtuelle Tuner)
- Add detect Tuner & Demodd automatically.
Geht es gleich weiter mit Update 08.12.2018, go ahead with new Update
add video setting support for videoenhancement plugin
oe-alliance/oe-alliance-core
Das nächste ist dann auch HDMI CEC ! soon too
Hi, i have question. Does wireless keyboard and mouse work with octagon 8008? Where it can be connected? I need this periferies to work for example with Kodi.
Thank You for info. I want to buy it as xmass gift.
And second question. Is possible to disable wifi? I only want to work with my LAN cable.
