Lan port test
Terryl
Custom built PC
Anyone know of a device or way to test the LAN ports on a router and switch, I need to check the in/out levels and is that port weak or having problems.
Why??? I had some mice problems by them chewing into the CAT5 cables and shorting them out.
System setup is as follows.....WAN modem to router, router has WIFI and 4 gigabit LAN ports, output of LAN ports on router go to 3 network switches and one main connected computer, outputs of switches go to multiple computers, 3 satellite receivers a Bluray player, a network attached storage device, 2 security DVR's, and a radio hot spot.
All equipment LAN ports on attached equipment have been tested using a second standby router, the switches need to be tested, the same with the LAN ports on the router, CAT 5 cabling is being tested.
I need someway to test the outputs of the router and switches to see if they are weak (low output levels) or in someway damaged, all the test equipment I have is for checking the continuity of the CAT 5/6 cable, I have no way to test an active router or switch LAN port.
All computers connected with WIFI work fine with out problems.
So I need someway to test the LAN ports to see what what.
Any ideas????
2cvbloke
Near Pontop Pike, Co. Durham
If the standby router works, why not keep the original as the spare?
I picked up a 24 way router in a charity shop for a fiver a couple of years ago, Netgear.
Why not use a wired broadband checker test on your laptop/PC , swopping the ethernet cable on each port of the switch ?
Long winded, but you will get figures of up/down speed, whichever port differs by a wide margin is most likely the suspect one.
Terryl
Custom built PC
The standby router is very very old all it has is WEP security on the WIFI, and I would not trust it for very long as the primary, I have a new one on the way.
I can try the laptop speed test and see what happens, I was looking for something that would plug into the LAN poert and give a go no-go LED readout, but have not been able to find something cheap.
Terryl
Custom built PC
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Terryl
Custom built PC
Yah something like that, I can do the loop-back plug but the other software stuff is beyond me.(I'm a hardware guy)
It would be nice if there was something that one could buy with software to test the in/out levels of the LAN ports, I suspect that the short in the cable may have done some sort of damage to a switch, I don't want to start replacing switches, don't have the budget for that.
If you weren't on Mars I would post one out to you.
Terryl
Custom built PC
Yah it would cost you more in shipping then for me to go buy one.
