- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Thank you, I trust they are DVB-S from the FEC.
Finding is one thing, tuning and watching is another! Did you actually manage to tune to this tp after blindscan? I don't think you could...This is not completely accurate; once (once) the blindscan of the MIO4K found a sr below 1000
| Radio Immaculée Conception | DVB-S | 128-3/4 1000 |
| Deutschlandfunk | DVB-S | 940-1/2 | |||
| Antenne Bayern | DVB-S | 477-1/2 1000 | |||
Telekom Austria | DVB-S | 556-3/4 | ||||
| Antenne Düsseldorf | DVB-S | 285-7/8 1000 |
Do you know if the 950MHz lower tuning range on the Mutant HD51 is hardware limited or is it limited in Enigma2?Silabs tuners do amazingly with low SRs (provided there is a correct driver combination) going down to 200Ks/s.
This means receivers such as DM920, SF4008/8008, HD51 etc perform well. The specs state lower SR is 1000 but fortunately it's not the case.
The new Availink tuner in Edision OS ninopro/mio4k refuses to tune anything below 1000. However the specs state a low of 0 ks/sec, and the steep cut is up for further investigation. I believe it's clearly a driver/firmware limitation that should be fixed in future releases. Having said that, the tuner states it can lock up to 60000 Ks/sec which is impressive if it's true.
