Real or fake ?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cruising youtube last night I found this rather bizarre video ...
Is it real ...or fake ..
sadly I dont understand russian ...but ..
If it is fake ..then it's an impressive trick.
If real ...it explains UFO sightings and the dark state secrets of various governments...
Prof John Searle (UK) made similar claims many years ago.
Comments welcomed..
rgds
VS
Comments welcomed..
rgds
VS
Well to me, anything with spinning discs and what appear to be magnets. and the contraption being attached to wires is inherently suspicious if the machine is supposedly running on 'free' energy.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Llew ...
From my limited interpretation ..
The lift is magneticly generated by rotating magnets ..on two planes in opposite rotation ....and is why it decends after the battery is disconnected ..
So ..battery only needed to rotate the motors ...and can be disconnected once rotation is acheived...but removing the supply causes the rotors to spin down ..thus lift isn't sustainable without rotation /power .
But if the power to drive the motors was 'on-board' ...lift would be sustainable..
All this assumes it is genuine..
but this could well just be a clever trick..
You can't deny it's an impressive trick or demonstration...depending on what you believe,
I remain sceptical but like mulder....I want to believe.
A similar basic pinciple being low level levitation using high power rotating magnets over copper plate ..
again using rotation in opposition to acheive lift and stability..
The science behind that being proven but needs huge power sources and generating much heat in the copper plate.
Hi Llew ...
Certainly an interesting demonstration. Trouble is, history is littered with many attempts at grabbing energy from unknown sources. Maybe the source for this one will be discovered in, say, a millennium or two :unsure
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
True or not Llew ..I dont see this as a 'free energy demo' ....
I find it more fascinating as a demo of levitation..
I just wish I could understand russian so I could better interpret his explanation.
be it crap or otherwise.
lol
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Well it is intriguing I have to say but I suspect the model he has built would be more stable had be built the damn thing square. It looks like he has guessed the dimensions of everything and made it fit together, the legs not even parallel with each other. It certainly has me foxed, or could it be some sort of pulsed magnetism perhaps? No I do not have a clue, but I have hundreds of old software CD's to give it a try at some point, if more details become available, but why three cables?
If it was true, or at least proven to work there would not be frigates being raised from the sea bed this week, nor would it be on youtube.
The circuit diagram halfway through the video suggests a high voltage grid, sandwiched between a potential drop, with a pair of rotating plates driven by two motors.
From the archives
Its not satellite - SatsUK
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So here is an analytical video which explains some fundamentals...
..and yes this very much follows principles discovered by John Searle ...and Nicola Tesla ..
..and yes as I supected based on electrostatics and opposing rotational magnetics ..
I noted the presence of a Tesla coil (high voltages indeed) in his demos .
This is definately getting more interesting..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
This video is over 2 hours long ...
If you want a definitive answer ..fast forward to 40:40 ...and the calculations state that Alexeys 'craft' can maintain its levitation height at around 10 mtrs above the earth surface..
Assuming our Japanese scientist is correct..
No wonder they shut Tesla down ..confiscated his lifes work ..and left him outcast and penniless
2cvbloke
Near Pontop Pike, Co. Durham
If it weren't for Tesla, we would have power stations on every street corner producing DC power as per Edison's "ideal" power, Tesla made AC popular through giving his idea to Westinghouse (they were close to bankruptcy, so he shared information to save them rather than sell it), who created transmission-efficient AC grids that could keep a power statin miles away, but with very little loss through transforming voltages up and down as and when required to reduce losses... :)
Kind of ironic to think that in the past 20 years, we've kind of gone back to the Edison way of local generation with solar power on peoples' roofs generating DC, which of course has to be inverted to AC to be fed into the building and/or grid...
AC doesn't get things off the ground, forwards/backwards, but it is useful until long distance transfer by DC is pefected by humans.
Resistance is futile.
(I'll get my {superconducting} coat)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
More antigrav fun ..
..and yes I do believe in the electrostatic principle of lift.
This is a variant of TT Browns lift principle and is based on research and principles that have been known for over 50 years.
Obviously this is very lightweight by comparison to Alexey's lift craft..but demonstates the capacitor/high voltage lift principle well I think.
no commentry just a short video demo..
rgds
excollier
Bikes, Booze, Rock & Blues
TD 64 and Humax Foxsat HDR with Raydon's custom firmware
County Donegal - furthest outpost of the EUSSR
flying sorcery I tells ya
