Advice Needed Green 'watch from start' button
aceb
Prof Tuner 7301 /
Sussex
I'm used to this appearing in the top right when using Freeview but should it also work on Freesat? Set up a new Smart LG TV with built in Freesat today, have set up and logged into iPlayer but I don't get the start again option when tuning into the BBC channels, should I?
I think it's confined to Freeview Play, not Freesat Anytime.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Yes because if you do use that function it reverts to IPTV streaming from the beginning, a function which is not available via satellite.
The Freetime satellite boxes work in the same way. But, as yet, they haven't embraced the restart function.
Topper
As the facility already functions on other platforms what could possibly be the problem, unless of course it is the geolocation copyrights issue
No idea. Maybe software licensing or summat tedious like that?
aceb
Prof Tuner 7301 /
Sussex
Thanks, at least I know it's not the TV at fault. I guess it's probably licensing that removes manual tuning when in Freesat mode even within the advanced menu, so no way of adding C4 HD to the channel line up.
Jimmy H
Leek, Staffs
LG43UH661V with region 2 sky dish
Leek, Staffs
It works fine on Freesat on my LG 43uh661v which is over 2 years old.
Good to know.
Jimmy H
Leek, Staffs
Leek, Staffs
I was referring to the green button rather than C4HD
