Want to resurrect your D/D2 MAC kit?
it was also d2mac 18 w tdf mcm and german channel rtl d2mac it work pal plus
A bit of soft encryption (not requiring a card) implemented for the D2MAC encoder - sent from HackRF to Echostar LT8700.
BSBSquarial
Vu+solo2 with 1.2m motorised dish
Sky Q ( yes, its as crap as the HD box)
BSB receivers by Ferguson,Nokia,Philips,Tatung, Deccacolour.
BSB Squarials branded Ferguson, Philips, Tatung and unbranded made by Matsushita. Nokia but unbranded made by STC.
BSB square dish unbranded and Philips round mini dish made by Channel Master.
East Sussex UK
This is a Great thread!
Did any one manage to successfully transmit video and audio to a DMAC receiver?
I have some BSB receivers that I'd love to be able to transmit to.
I also have a Rohde & Schwarz SGDF D / D2 MAC Video GENERATOR.
Any pointers on how to transmit to one of my BSB receivers using this?
Chris
We are using hackrf device with hacktv (Google it) but the MAC part is not yet released. The generator just generates test cards. It doesn't convert PAL to MAC.
fsphil
Still playing with analogue. Also running a Humax FOXSAT-HDR and a Thomson THS804.
It was one of those test card generators that kicked off this project :-)
BSBSquarial
East Sussex UK
Hi Phil,
so if I wanted to transmit to a BSB box do i just need to buy a HackRF and download the Hacktv software?
How do I go about running the scripts you have online?
Sorry. I'm not very good at the software/programming stuff. Haven't a clue really but I've been dreaming of receiving a signal on one of my BSB boxes for years now.
Regards
Chris
fsphil
Potentially, but I wouldn't get one just yet. hacktv doesn't have D/D2-MAC support yet, but it's coming soon(ish) in the next few weeks.
Also the BSB receiver requires D-MAC which is a bit trickier for the hackrf to handle due to the higher speed of the digital bits compared with D2-MAC, so it might show only video with poor sync and no audio. I have a BSB box here so I'll give it a test and report back.
BSBSquarial
East Sussex UK
Great thanks.
BSBSquarial
East Sussex UK
Hi Phil,
any luck with testing the BSB box with the DMAC transmission?
Chris
fsphil
Ah good timing, I just got the MAC gear out last night again. I have a Philips BSB STU902 set up at the moment, and it's not working too well:
123968
The decoder doesn't seem to be handling the digital data well at all, so it's not staying synced and there's no audio. The colour is also wrong, which I can't explain at the moment. It did seem to decode some digital data though as the 16:9 > 4:3 crop is enabled, which is a setting in the line 625 data.
I'm going to be trying a few new ideas on how to generate the signal, but it might not help.
BSBSquarial
East Sussex UK
WOW a new image on a BSB receiver.
I am impressed. I'd love to be able to get this working on my BSB receivers.
Let us know if you have any more luck.
Chris
zermok
no satellite.
canada
sorry for my newbie question, I'm looking for an audio video obfuscation encoder/decoder with if possible a key, something like this
how this line
/* Calculate the active line number */
vy = (s->line < 313 ? (s->line - 23) * 2 : (s->line - 336) * 2 + 1);
+ if (s->frame%400 > 100 && s->frame%400 < 200) vy = (vy > 0 ? rand() % 200 + vy : vy);
if(vy < 0 || vy >= s->conf.active_lines) vy = -1;
can be used in case of an ffmpeg command line in real time?
- could it be decrypted on the fly too?
zermok
no satellite.
canada
I talked about ffmpeg because it's widely used converter and unfortunately there is no such kind of option to create discret11/nagravision encryption.
To be more explicit:, I'm developing a browser extension that intercepts an audio/video stream and apply an encryption/decryption (with a key if possible) like nagravision or discret11. Do you think there is a way to do it?
Not unless you write your own ffmpeg filter (or some other method). This is not what HackTV was designed for...
BSBSquarial
East Sussex UK
Hi Phil,
Have you have any more thoughts on how to get the DMAC working?
Chris
Does anyone remember whether BSB used Eurocypher and what it looked like? I assume it was very similar to Eurocrypt given how easy it was to convert those boxes to D2MAC...
BSBSquarial
East Sussex UK
BSB did use Eurocypher which I believe was a variant of Videocipher II.
It was a joint venture between BSB and General instrument.
