30 W Feeds
Tururu
Assembled with recycled parts
Recycled as the owner.
Hispasat . 22-12-2018
pontiend
Contibruter
south yorkshire
Two feeds here tonight.
ETT-8 COD1
12000 H 9999 8PSK 3/4
Overon E333 FEED2
12015 H 4999 8PSK 3/4
TBS 6983 105 cm Dish
pontiend
Contibruter
south yorkshire
CAN-3 v
12017 H 5631 3/4
E260.ATM4
12026 H 7199 8PSK 3/4
DEFAULT
12587 V 7199 8PSK 3/4
E-401 TF-1
12605 V 7199 8PSK 3/4
TBS6983 105cm Dish
pontiend
Contibruter
south yorkshire
Another one.
NTT-4 HD
12004 H 14997 8PSK 3/4.
TBS6983 105 cm dish.
pontiend
Contibruter
south yorkshire
A few feeds here tonight.
HOL-302 VIA 1
11563 H 6654 8PSK 3/4
E-455 Via1
12016 H 4799 8PSK 3/4
E-400 VIA1
12027 H 5631 3/4
AD_44_VIA_2
12601 V 4799 8PSK 3/4
TSB6983 105 cm Dish
pontiend
Contibruter
south yorkshire
GCANA
11521 V 5631 3/4
NTT-4 HD
TBS6983 105cm Dish
Adam792
Cheltenham
Can anybody see any kind of signal on 12530V (DVB-S2 QPSK 1041 3/4)? It's meant to carry Portuguese radio station feeds in DVB-IP, and I was able to lock it for a while last year, but I no longer seem to be able to get anything from it at all. I'm not sure if that's because of the non-standard format though or because it's either been removed or changed frequency.
I can lock the Spanish IP stations on 12518H consistently, and they're in the same format.
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Yes, it's still there.
Adam792
Cheltenham
Adam792
Cheltenham
Didn't notice from your screenshot, the frequency is actually more like 12528 or 12529. Sure enough, I've just changed my transponder frequency to 12529 from 12530 and Rádio Comercial/M80/Vodafone FM/Rádio Cidade/Smooth FM are booming in now. :D
Easter Religious parades from Spain
11571 V 7200 HD id= Palmasat Sng-2
pontiend
Contibruter
south yorkshire
Three feeds here.
TCLM04_E291_VIA1
12003 H 4499 3/4
CM1 VIA2 ESK61
12009 H 4443.3/4
OVERON-E 96 VIA 1
12036 H 7199 8PSK 3/4
TBS6983 105 cm Dish
Edit 12003 dead now.
pontiend
Contibruter
south yorkshire
This looks like a wildfire somewhere. Probably Spain.
BGVR3-via1
12588 V 4799 8PSK 3/4.
TBS6983 105cm Dish
Adam792
Cheltenham
Flysat reporting the Aragón TV DTT multiplex as being newly on 30W in PLS.
11330H
9140
3/4
DVB-S2 8PSK
PLS GOLD+53850
Can anyone lock this or is it now off? I can't get any sign of a signal at all.
11330H
9140
3/4
DVB-S2 8PSK
PLS GOLD+53850
stephan94
Bavaria
Hi ,
new code for Aragon TV
before: Gold 53850
now Gold 174526
the NinoPro and the MIO4K, found it immediately.
the SX88 + failed to find this frequency, by blindscan or manually.
this probably confirms what MCelliotG was presenting.
the Sx88 can found an MIS only if he has the PLS in his databank
