OCTAGON SF8008 E2 4K UHD
Blindscan T2MI (T2-MI) Octagon SF8008
Express-AM7 @ 40° East
Express-AM6 @ 53° East
Was the alpha png blending issue forwarded to the manufacturer?
Another issue discovered is the bitrate does not work properly on encrypted services. Problem is the same with both the bitrate plugin and bitrateviewer on O-E images.
With tomorrow Images T2-MI Scan one more time imporved. Is enough install Online Updates.
Enjoy ) nice weekend.
Do the Open ATV Beta 6.3 images have these updates or just the 6.2 Images?
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 08.04.2019
- Sound problem from Stand-by fixed.
- Standby looses audio fixed.
FTP install:
hi-dvb.ko --> /lib/modules/4.4.35/extra
Telnet & Putty:
a) killall -9 libreader
b) libreader --> /usr/bin (ftp)
c) Box neustarten (restart Box)
Ab morgen Images.
From tomorrow Images.
Yarinki imajlardan itibaren.
audio passthrough output in dts and ac3 ac3+ etc works well. youtube i dont know, need test
look kodi 8008 video, works really with good performance.
Hello,
Kodi Screen resolution will be only 1280x720?
This limitation has to do with Images Teams or the reciever?
Currently i have openatv 6.2, I'm waiting for sd card for test other images.
Do you know of some image that has Kodi at 1080p?
This fix off sound will be available by update?
Thanks.
OCTAGON SF8008 4K UHD E2 Updates 10.04.2019
- Add Inverto IDLU-UST110-CUO4O-32P (Unicable)
- add missing dat time changes
- [FileCommander] add path to script parameter
- [FileCommander] fix title for translation
- [FileCommander] fix possible bs
- [FileCommander] add setTitle in FileCommanderContextMenu
- eDVBFrontendParameters FEC add.
- scanStatusChanged update
- eDVBTSTools update
- EPGlist update
- Movielist update
- Addons key actions update
- [T2MI] ScanSetup.py: fix selecting wrong T2MI transponder
- Add missing FECs for dvb-c2/t2/s2
- ServiceScan update
- ScanSetup update
- Transponder parameter update
- Fix rewind freeze
Ab morgen in den Images!
From tomorrow in images!
Yarinki imajlardan itibaren!
- EPGlist update
- Movielist update
- ScanSetup update
- Fix rewind freeze
Is online update OK with these fixes?
