MCelliotG
- May 10, 2015
- TBS 5925, Mut@nt HD51, EDISION OSMINI, MABO 130X144, DRAGONSAT DS3000 LED MOTOR, INVERTO BLACK ULTRA TWIN LNB
- Thessaloniki, Greece
The IF frequency is unrelated to Symbol Rate.
If someone has managed to tune to the 25.5E amateur band with TBS5520 and an unmodified LNB, then probably the Silabs tuners on E2 receivers will too.
BTW, I made a low SR test with the Availink tuner of my OSmio4K. I tuned to the Polish radios on 39E on 11479H SR1000 via the Satfinder. The frequency is tuned with no problem (just a slight delay which is normal in this case). Once I input SR 999 which in any other tuner would also tune the frequency the signal is completely gone.
This is to prove beyond any doubt that the SR1000 limitation is simply defined in the firmware and not the hardware of the tuner. It should be reported to Edision immediately.
