- UK
I can check later this afternoon, though I am feeling distinctly under the weather atm.
Yes, yes and yes...
Anyone know why on Hispasat 30W with a 95% SQ 11496H Multstream the picture wants to break up.?? Everything else OK. Does this need one of their many software updates???!!!
On the Octagon SX88+ there is no problem on a smaller dish. Strange.
Tuner related apparently..Breakup confirmed on all 6 channels scanned, including the radio stations.
Thank you! I went ahead and bought the receiver from WOS and they've pre-flashed it with OpenATV. Does the blind scan work with this image too? (i.e. do I need to install a plugin to make it work/show?)Yes, yes and yes...
Yes, no problem blind scan works with ATVThank you! I went ahead and bought the receiver from WOS and they've pre-flashed it with OpenATV. Does the blind scan work with this image too?
Blind scan is included in the image.Thank you! I went ahead and bought the receiver from WOS and they've pre-flashed it with OpenATV. Does the blind scan work with this image too? (i.e. do I need to install a plugin to make it work/show?)
Sorry I know these can come across as really silly questions but I'm coming from an Openbox V8S and a VU+ with a very very early image of Blackhole.
www.octagon-germany.eu
I have the new firmware installed. After changing the language to English I have found there are pages within the tuner set up that are part German, part English.
is ATV Image problem 3rd May Image, pls install available Online Updates and problem will be solved.
I always get this no matter what image I use, just re-start the GUI and it will be OK.I have the new firmware installed. After changing the language to English I have found there are pages within the tuner set up that are part German, part English.
