28'2ºe astra, among the changes of the day, new channel in 8k uhd (ses test). 3-5-2019
Tururu
Assembled with recycled parts
Recycled as the owner.
28'2ºE Astra, Among the changes of the day, new channel in 8K UHD SES Test. 3-5-2019
11973 V 31000 2/3 DVB-S2 8PSK HEVC.
New Test 8K SES Test 8K (7680×4320).
The file generated during 1 minute of recording of the channel in 8K is 410Mbs.
Tururu
Thanks for the photo, and the correct FEC 9/10.
With the equipment that I have the FEC gives equal/auto.
stephan94
Bavaria
from northern Bavaria still receivable with 1,20m.:)
MCelliotG
Thessaloniki, Greece
No signal on my location with 1.30 as expected. Even though I receive all other 2E "Europe" beam TPs, this one requires bigger dishes (unknown how much).
Stephan what's the SNR of the TP, is it only 12db in your location as I see on your screencap? This is low for the beam in Germany. Tururu's 98% makes no sense to me (sorry)!
Tururu
@MCelliotG
That value is not worth anything, forget to cross out, put the signal/SNR in dB but without converting/calculate, forget. , forgetting.
I do not have a meter :-doh
In the receiver Dreambox800S-HD it indicates 18.5dB, (125cm Madrid-spain)..
Ese valor no vale para nada, olvide tachar, pone la señal/SNR en dB pero sin convertir/calcular, olvidar.
No tengo medidor.:-doh
En el receptor Dreambox800S-HD indica 18.5dB, (125cm Madrid-spain).
stephan94
Bavaria
It's my reception of the north of Bavaria with 1,20m
We can see that the Linc Margin is only 1.4 dB, but it looks stable in the day, unlike the transponders of the UK beam which in the evening are no longer receivable from my place of reception.28°2E_1905061644_10700-12750 V.jpgempfangsort.jpg
stephan94
Bavaria
Is the 8K test channel currently transmitting ?
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Very strong signal here with a 45cm dish "Only audio with my A4K UHD"
OK, I'll swing the dish around once the wife has finished with the Moscow plane crash.
It does not find it with the blindscan, it is necessary to indicate all the data.
Thanks, surprisingly the Amiko A4 found it with a basic scan
Stable reception here, 12,2dB and 0 BER on the updated 8008 (80cm dish , W London)20190507_080203.jpg
Tururu
28'2ºE Astra, End test 8K and the channel SES 8K (7680×4320). 18/19-5-2019
They finished the tests in 8K (7680×4320), only test carrier without channels.
@Tururu :),Indeed,11973 V,31000,9/10,8PSK-no 8K test now
Tururu
28'2ºE Astra, again a test in 8K, SES 8K demo Channel . 20-5-2019
Again a test on 8K, SES 8K demo Channel (7680 × 4320).
11973 V 31000 FEC9/10 DVB-S2 8PSK HEVC.
Sunday only carrier without channels, this morning bundled, this afternoon, new test, with bitrate of video 55-64Mbs, Bitrate audio 128kbs.
I do not have the machine power to watch these recordings.
El domingo solo portadora sin canales, esta mañana liado, esta tarde, nuevo test, con bitrate de video 55-64Mbs, Bitrate audio 128kbs.
No tengo potencia de maquina para ver estas grabaciones.
8K back on_28.2E
Tururu
28'2ºE Astra, Changes, Again SES 8K demo Channel. 18-7-2019
Bitrate de video 78Mbs (peak), Bitrate audio 128kbs.
