Badr7 26e
Hello i try got signal 26e 10970v nw africa beam on 3,6m dh no signal any member got signal
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I can not check ATM, but couple of years ago this transponder was receivable at my place.
ocean04
Vaasa
Western Finland (63N 22E)
Currently 10970V 6.2db 3m+SF8008. (Used to be 2db stronger)
10998V 10.2db
RimaNTSS
N-E from Riga
ocean04
Vaasa
That ir day-time dependent, cuz during the day signal is changing considerably.
It's not normal signal variation. 10970V was possible here with 1.8m 2016/17, but not anymore. It's actually -3db average (was using 2.4m back then)
Try it your self, see if you can get 8db values today. Same time you can check Eshail2.
10730H 30000 5.5db (Nobody has reported to Lyngsat)
10850H 27000 7.5db
11350H 30000 4.0db (Wrong satellite in Lyngsat)
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Gibertini OP100L, Southern Peloponnese
stel883_
Vátika, Greece
RimaNTSS
N-E from Riga
Pointed antenna towards Badr @26*E. Scanned all possible transponders and put all data in the spreadsheet, then created the graph. BadrSignal2019.jpg
Pointed antenna towards Badr @26*E. Scanned all possible transponders and put all data in the spreadsheet, then created the graph. View attachment 125133
Nice, that is an interesting way of presenting a scan result, it looks good, an excel chart version of a scan. Did you exclude any signals from E'sh-1 at 25.5E ?
RimaNTSS
N-E from Riga
I like this way better than presenting lots of screenshots. You are right, Enigma2 does the scan and creates txt file, than I transfer data to excel and make graph. That how txt data looks ScreenHunter_904 Jun. 25 00.13.jpg
P.S. Yes, E'sh-1 @25,5*E transponders are not included.
Lexzie
TBS 5925 USB-tuner
The Netherlands
How to create such a textfile or where to find it?
There are options with EBSPro to create excel files and charts for satellite scan results.
To save the result of a single scan with EBSPro:
1. Tick the "save tps in a file ......." box in the blind scan options screen.
2. Select xml file format.
3. Nominate a folder where the single scan file result is to be saved.
The output xml file can be opened in excel and a chart created.
EBSPro also allows the entire scan results database to be analysed. This contains the results of all historic scans unless it has been emptied at which point it starts again and saves all scan results moving forward. There is a topic on how to work with the EBS Pro scan results database available from the link below.
Returning to 26 East, I have attached below a chart and a table that present my miserable effort at scanning this cluster of satellites. From a UK location you need a big dish and a favourable geographic location with respect to the beam footprints.
I achieved a lock on some of the transponders but was some way adrift of securing a lock on the others. The Badr-4 frequencies were easily lockable but a toddler with a dustbin lid can pick those signals up, they offer no challenge to the UK located extreme fringe men. For the satellites at this 26 East cluster other than Badr-4 I had very limited success, more dish acreage is needed.
I included two data points in the chart, the column in the foreground is the signal level required for a lock, the column in the background is the signal level I achieved. Hopefully the use of two data points per frequency provides comparative visibility of the lock level and the signal achieved level?
The chart in the above post was a bit congested and included contributions from the dustbin lid satellite (Badr-4). I have removed the Badr-4 scan results from the chart source data set and refreshed the chart. Also, the frequency axis of the chart now includes the satellite and beam information.
In addition, I moved my SNR signal achieved levels to the foreground and placed the corresponding lock levels in the background. It may possibly present a clearer view of how far I was away from a lock on some of the frequencies. You gotta go large on this Bad Boy cluster of satellites from a UK location, I am scratching around getting very little success and managed a lock on only 9 of the 29 frequencies in the chart attached below.
We need a UK Big Dish Man to come along and sort this Bad Boy out.
ocean04
Vaasa
10730H 30000 and 11350H 30000 are Eshail2 as noted before. You should also receive 10770V 27500
Thank you for pointing out the incorrectly allocated satellite.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Getting a signal from 10770 V 27500 but no picture/audio.
125164
10770 V, SR27500 is from Es'hail-2 at 25.8 East on the MENA beam which needs 7.9db to get a lock. I am getting 3.6db to 3.8db fluctuating with a 1.5m dish, way below lock level.
