Channel master frankensteined
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Hi! Under the influence of another thread I have decided to play little bit more with CM 1.2m antenna, namely to convert it to double-reflector design. All I need is to make set of parts (mostly INOX) which will allow to nicely install Fibo bottom feedarm with the subreflector and feedhorn, or even without Fibo feedhorn to play with standard Ku or C band LNBFs. Feedarm, subreflector and feedhorn from 1.2m Fibo or 90cm Fibo can be used here. Actually, set is almost ready, only sidearms are missing (need to buy some INOX 10mm tubes). At the end of the day I will have 2x CM 1.2m installed shoulder to shoulder, one in usual setup and another one in double-reflector mode and then see which performs better. By theory dual-reflector antenna systems should bring ~10% better performance, side-lobes and X-pol minimized.
Beautiful work. Very tidy!
Trust
Nijmegen Netherlands
RimaNTSS
N-E from Riga
Also done the feedarms. It is not so easy to find the proper position of the sub.... first I need to tune antenna to some satellite in the normal setup (just main mirror and LNBF in focus). Then, without moving the main mirror, sub should be installed and manually find it's proper position by maximum signal. I've done this procedure several times.... yes, it takes time :confused, but that is fun! :Y
Any chance of making this for the 1.8m? :D
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
RimaNTSS, you are truly a dish Master
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
You are very skilled indeed
RimaNTSS
N-E from Riga
Thanks all!
The only difference here is the length of feedarms. And, because of the different length the diameter of tubes should be different as well. For 1.2m antenna 10-12mm tubes for side-feedarms , but for 1.8m antennas 14mm tubes are better be used. I will probably do the set for 1.8m CM dish soon to see how it works.
RimaNTSS
N-E from Riga
Well, there is some difference between 1.2m and 1.8m dishes.... and not only sizes of the mirrors. For 1.8m dish it is more appropriate to use M8 bolts & nuts , but for 1.2m dish M6 is more than enough. Of course, feedarms are in different length and different diameter tubes are used (12mm for 1.2m and 14mm for 1.8m). Other-ways nothing more differs and it is only matter of tuning, adjusting and tests.
samoloko
1.8 PFA
EU
very nice Rima,
how much dB did you gain with fibo sub reflector mod on CM 1.8
RimaNTSS
N-E from Riga
Alex!
Theoretically, Gregorian and Cassagrain design of antenna system performs ~10% better than single reflector system. When I was experimenting with double-reflector systems I felt that performance was a little better (not worse for sure) than same antenna without sub. Another point is it is fun doing such experiments. We are talking about hobby, do not we? :D .
@RimaNTSS - good to hear from you again (not much lately!) :D
How's the health situation in your neck of the "woods"?
RimaNTSS
N-E from Riga
Hi, All!
As I have found out that several forum members are interested in transforming their offset antennas to double-reflector ones. I fully support this wiliness, as I personally see real potential in this transformation. I have gone this way, and I am pretty satisfied by the process itself and also by the performance of dual-reflector systems. The main question by users was about how to do this transformation? I have an answer…. In 2 parts. Part Nr.1 – theoretical. Part Nr.2- practical. Should we discuss those parts one by one?
Hi, All!
Wok do you suggest first ?
Opening this old thread..This is on my 'to have a go' list now...Have you saved any measurements, angles etc for the 1.8m Rima?
Hi, All!
You know..... I still have the parts you sent me in 2019 to put this together and with everything going on, I never got around to it! I have a lot of plans on my list for CM and this will be one of them.
RimaNTSS
N-E from Riga
I was exploring possibilities for making the SUBs, but came in to the conclusion this makes no sense. So, the best way, IMHO, is to use factory made SUBs, feedarms and feedhorns from Fibo antennas.
I see INOX bits have been added to the 1.8 design, I take it these can still be made by yourself?
