Yes they are listed but no signal?They are still listed, on lyngsat, broadcasting in DVB-S2X:
Code:https://www.lyngsat.com/Eutelsat-33E-and-Intelsat-28.html
12598V still working here. Your dish size?Anyone got those channels right now??
Yes dear i have android 4k receiver supporting S2XWhat make/model receiver do you have? Is it DVB-S2X compatible?
Yes my set up is motorized 180cm prime focus dish getting all channels of 33e excluding Bulgarian package and polsatYeman is on the limit of this transmission @ 33.1 east you will need a dish size over 120cm to get the S2X transmissions if you live in the South Yeman region.
Thanks for the info.12598V still working here. Your dish size?
You are totally right... This's what happened with me in last three months...This TP is now transmitted with reduced power, about two months ago, I could receive it with 16db and now it's only 12.2db!
Bearing in mind that I'm inside the official footprint with a 1.30m dish and the signal needed for lock is 11db, it's no wonder it has disappeared in much smaller dishes and especially in areas where the signal is not supposed to be powerful!
Same behaviour goes with some MIS Tps on 30W!
Works fine here even 7.2db (Octagon)signal needed for lock is 11db
Here it is with 110 cm dish = 12 dB
Edision OS Mio S2X tuner
TF1 HD Suisse, TMC & TFX are working fine
