Ka-three band lnb with gilat
dreamsat
germany
Hello,
I have modified a Gilat AN 8002 LNB so that all three bands (A, B and C) in the KA band can be switched with one LNB. With the polar converter presented here it is now possible to receive all four polarizations H, V, LHCP and RHCP as well as band A-B-C with one device. The annoying replacement or a complex LNB changer is eliminated. Unfortunately, I am unable to reach Band D with this LNB. Currently, I lose about 2 dB in band C above 20900 MHz.
I will try to modify the filter to compensate for these losses.
Everything is controlled with the POLOLU controller.
best regards dreamsat
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Do you still use it ? I've got a brand new 8002 I bought last year off eBay very cheaply but still not tried to convert it, would you possibly obligue I wonder ?
dreamsat
germany
Of course I use it. I am currently building a LNB changer. KA-1,2,3 Band>> Ku Band>> KA Band 4
Trust
Nijmegen Netherlands
I do have this unit , recieve channels from 16º and 7º E with it .
Same signal strenght as with Inverto KakU lnb
@dreamsat is this the same as GILAT , inside the RX part looks the same , what to change for all Ka bands ?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
OK great so would you consider converting mine for 18.2Ghz ?
dreamsat
germany
Hello Trust,
i have the Gilat 8002.
You have the 8004. I'm still looking for it but there are none at the moment. With this you should still come down an area further. 20,200 to 21,200.
regards dreamsat
Trust
Did some work at that 8004 to reduce the weight .
Took the RX part out and made me a angled waveguide part to connect the feedhorn , not so good , gave me a loss of 2 dB.
Overnight came the idea to cut out the intern waveguide , did not test it but should be OK .
Gilat 8004 waveguide mod 3.jpgCutting out waveguide1.jpgCutting out waveguide2.jpgSeparated RX.jpg
dreamsat
germany
hello Trust,
can one build there now two LNB ?? Is this a Orthomode???
regards dreamsat:Y:Y:Y
s-band
Essex
@Trust yours is neater than mine which were hacked with a chop saw. Here's a pair of band B with external reference, fed via a splitter, . It works reasonably well shifting the elevation axis by about 3 degrees and using a co-ax relay to switch between them.
If anyone, who has taken a Gilat ODU apart, doesn't want the TX part, I'd be interested in the board shown here.
<edit> My linear arrangement added
dreamsat
germany
Hello s-band,
i have a ODU TX Part from a AN8002 for you.
regards
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Can anyone offer to mod my AN8002 or can I do this myself quite easily ?
tempo
47.5N, 42.2E / Russia
Hello,
Original Gilat AN8002 LNB has frequencies of Ka-band B:
RX = 19200 - 20200 MHz,
LO = 18250 MHz.
I have read this thread, but unfortunately there are no details, how to convert it to the Ka-band A or Ka-band C.
@dreamsat1, may I ask you please to share with us your knowledge, how this Gilat AN8002 LNB can be converted to Ka-band A (18200-19200 MHz)? What changes should be done with electronics?
Some detailed "howto" tutorial would be appreciated.
Seems to me, I've seen some your photos and info about RF band-pass filter and local oscillator modification somewhere, but can't find this info again.
I think this thread would be a right place for all interested people to find all the necessary info about AN8002 hardware modification.
