- Oct 21, 2006
- See signature
- North Somerset
@homercartman I've pushed the latest version to generate C+ France "free access" mode control words. Enable it with --syster cfrfa.
Now, on my system, two white keys work with random CWs, one white keys only works with fixed ones and the grey one with a different ATR does not respond (it's blank - no dates on it). I would be very interested to know in how it performs on your setup - C+ France and C+ ES keys. My grey key expects VBI data on different lines from white ones. So you need to edit this line from -1 to -3.
I expect some C+ France keys to work - at least in fixed mode (controlled by _CFR_FIXED flag in syster.h). I would hope that C+ ES keys at least trigger the decoder but I don't know what the ATR for it is and therefore I don't know what lines it expects VBI data to come in on. It probably won't do anything. You can play with the value above as well to see if any of them start poking the key.
C+ France key will force the decoder to permute the entire line, so PAL mode will lose colour. Use one of the SECAM ones.
Lastly, would you be able to translate Note_cle.pdf file for me? I ran it through Google Translate but it doesn't do a good job. I am interested in getting more detail into the structure of 06 messages and what makes it valid or invalid. There are mentions that changing single bits on either of the 8-byte halves will make the key respond with 0A, though, as I've found above, some C+ France keys will take random ones in free access mode.
hacktv/syster.c at 820df93d48b375c2fee6f9989de1bb8437881845 · captainjack64/hacktv
Analogue TV transmitter for the HackRF. Contribute to captainjack64/hacktv development by creating an account on GitHub.
github.com
