Amos-17 C-band HTS in sub-Saharan Africa
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hi John,
thanks and I have not tried in linear...
Hi John,
thanks and I did not tried in linear...
Just looking at my analyser plot Edgar for 17° E - - can you see a very low level fairly wide Hor signal at 3993 H ? .... it's not there on V or circular and does not seem to be coming off one of the satellites either side of 17° E
dx qwer
Rastatt/Germany
Yes I can see 3994. I´m just in circular - had to test in linear soon (when there is time)...
dx qwer
Rastatt/Germany
Indeed - these signals are inlenear horizontal!
dx qwer
Rastatt/Germany
... and 3994 H active again, but not lockable here.
SR looks like 30000 - thanks to marval450 on SatelltesCommunity!
dx qwer
Rastatt/Germany
3826,5 V
Europesat
strong
Yemen
Ku band now active 11719 v 30000 carrying some fta African channels on Africa beam ....
Ref. Flysat
Europesat
strong
Yemen
OK i did not c that post ... Thanx
Bigger reflector needed here - anybody make anything of this
Anonymous_1
nothing lockable, but maybe just a txp on, ready to transmit..
128090
Thanks ...
Also - a large difference in received strength with you, not sure which size reflector your on but your location seems to be in a stronger footprint area or possibly part of a steerable beam ? ..... i'll have another look to see if it's come up a bit in strength.
Lexzie
TBS 5925 USB-tuner
The Netherlands
... Same results as Feedsat with me here in Central UK with a 2.2 PF.
Empty apart from beacon at top end of band and the few data freq's at the bottom end so just looks like they are using one of the dedicated spot beams at the moment.
Monitor this position for Ka & C band activity on a regular basis with H/V/L/R polarities but nothing exciting to report up to yet..... would also like to hear from any locals of the area with any more information .. eg the extended high band Ku frequencies 13.4 - 13.6 GHz range and of any suppliers of the required lnb etc.
dx qwer
Rastatt/Germany
Nothing from Germany on 4,9m from these ones - flat spectrum...
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
Nothing from Azores on 2,4m .
... these three signals are a bit stronger today with me since two days ago but i can't resolve anything
