Eutelsat 5 West B
Alejandro_V
Channel Master 120 with Inverto PLL LNB
Oslo, Norway
Th
11679V/29950 and 11471H/9900 (84 radio stations pos.91-174 , and TV-VEOA Occasion) can scan, but TVs are scrambled.
11679 - with TV tuner:
11471 - with Ariva 102HD tuner (the same 1.2m dish):
Thanks! 11679 is not yet migrated to E5WB so it's normal that you get still get it. 11554 has migrated and there you have one FTA channel (fransat info) have you tried that?
Nothing at all on 11509 right now ...... signal was much better in the late afternoon yesterday, so will check again later.
No problem to bung up my 1m dish, though, in due course. Might even reinstate the TD110. There's fun.
All locked now ..... definitely improves later in the day.
Edision Primo & SX88 OK now with France 2/3/4/0 ect so it must have been a transmission fault.
100% Hunky-dory.
Great signal, even on an 80cm dish up North - and no glitching :)
Red alert
Inverto ultra 0.2db, Edision Mio 4K, 1m Gibertini XP on Superior Dark Motor.
R.I.P -> Technomate M3 and Stab HH100.
Manchester
I'm not getting any signal on 12522 V 35500 2/3 . This was working fine 2 days ago. Is this frequency working for anyone else?
Full bore.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Why are the Mediaset transponders transferred to 5W B when they move to 9 east? Just to cover the weeks until all the dishes in Italy are repositioned?
100% Hunky-dory.
Thats promising - I will try an 80 if its warm enough to play with the dishes this weekend.
dreambox1959
46.3N-4.3E-FRANCE
france
i have never seen a screen like that !!!! 99%
ok i have a 2 meter dish !
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Th
Thank You!
11554V -weaker signal now
128332
Yesterday was scanned:
128333
I'll check in the next days again.
Acc. to Flysat & Lyngsat 11471H/9900 is migrated on 5W B.
mujek
Fuba DAA 850: Multifeed 28.2/23.5/19.2/16/13/9/4.8° E
DVB-T2&DAB+: Germany&Czech Republic
Dresden (Germany)
Dresden (Eastern Germany) - eastern edge of the Transalpine-Beam
I lost about 2dB on all transponders that were transferred the other night.
On my 45 cm dish I still picked up all the Fransat Transponders, but I lost 12648 V and 11509 H was hardly there.
I'm fine now after an upgrade to 65 cm, even under the current wet conditions.
Tests done with 1.50 m and 1.10 m antennas in my area after MIS transponders were moved to E5WB.
Adam792
Cheltenham
Signal seems back up to nearly what it was on 5WA on the multistreams again here today, in cloudy drizzly weather too, after yesterday evening's slight dip.
Very happy to keep such easy reception of the multistreams with their superior EPG data and lack of encryption! I don't know why they can't manage more than just now and next on Fransat.
More info come eutelsat 7a problem move to 5w
MCelliotG
Thessaloniki, Greece
The signals are even better today, especially during daytime, standing at exactly as strong now as they were on 5A!
During nightime they lose about 1db!
11480H is extremely powerful at 20.2db. That's hardly indicative of the printed footprint for my location (I should be about 80km away from the 48dbW), the beam is definitely shifted a bit towards the east!
11480H cannot be tx'd on the TransAlp beam as I can get it with a 13dBW signal here on the 43cm dish. If its moved its on the main Europe beam. (Im getting nothing whatsoever for the freqs we have identified as being on the TransAlp beam).
For the record 11454H is also visible here at ~7dB
Adam792
Cheltenham
I'm getting that one (11480H) with an absolutely stonking 21dB of signal! I think that's the highest signal of any transponder I receive here across any satellite.
I don't remember it being that high before, and as 11471H is a new one which would also be part of the same transponder (just split up) then I'm guessing it's moved. It seems like they're using 11471H as a narrower version of 12690V so that it can use 5WB's limited transponder space (sharing with the other narrow radio transponders) and not an entire transponder on its own.
As you say, must be the European-wide beam.
