salocin
- Vu+ Duo 4K X2
Vu+ Solo 4K
2 satellite dishes: 28.2E & 5W
- West Cork, Ireland
I'm getting that one (11480H) with an absolutely stonking 21dB of signal! I think that's the highest signal of any transponder I receive here across any satellite.
I don't remember it being that high before, and as 11471H is a new one which would also be part of the same transponder (just split up) then I'm guessing it's moved. It seems like they're using 11471H as a narrower version of 12690V so that it can use 5WB's limited transponder space (sharing with the other narrow radio transponders) and not an entire transponder on its own.
As you say, must be the European-wide beam.
11480H is still on 5WA!
