- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
I've had a delivery of the later style Hybrid LNB from Visiblewave that I thought might be like the others with an elliptical feedhorn, but it is a standard 40mm collar with suitable clamp for the Mk4 Raven dishes.
This was to have been bolted onto a Mk 2 dish at a client's house with the larger feed support, but of course the Mk 4 clamp won't allow that. The Mk 2 clamp won't fit round the LNB collar with the only option being to cut off the skirts and somehow bolt it to the support, which will look messy.
So, is there an adapter that converts 40mm LNBs for the Mk 2 dishes ?
