There is one chap in Riga, selling some antennas. It is 70cm PFA View attachment 130988 , and also lots of glass 1.2m antennas (just guess the brand :confused ). As far as I understood, they are on Az/El mounts.
"Whot a lot he's got":lol:
PS: do you mean "glass" or "glass-fibre"?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
You name it! I am not native speaker :confused
TBH, I've seen not many Channel Master antennas on roofs in my country, to be precise only 2 (not counting mines), but there he has so many!
Tell him to join the forum and advertise the dishes here - might find a buyer or two IF the "price is right" :D
RimaNTSS
N-E from Riga
Shipping price will be "the killer". I have already researched that and did not find adequate solution. :(
Got to be "dirt cheap" then :D
Love that 70cm PF dish! The LNB mounting looks to be for C band?
2m (actually 1.8m?) Channel Master. I am sure it's the one that @scopus donated one to me. A bit ambitious at 600 Sovs.
subman
echostar 3600
essex
Well turn the clocks back to 1990 I was watching premier channel on intelsat 27 west that was on a 1.8 IRTE system that dish and polarmount was £395 trade from Micro X .
Would go for this if I lived closer, grab a bargain including a Jeager 1224 EL version, needs a bit of TLC...
The 1224 will clean up nicely, definintely worth £100 as an introduction to motorised satellite with a 36V motor.
subman
echostar 3600
essex
Hi Guys MB + Scopus How many dishes have of you got installed at your house I wonder ? Only got 1 here but my back garden faces south but I even had to get planning permission for for that .
90cm Channel Master in Amersham, can't see the mount 99p
https://www.ebay.co.uk/itm/274411854955
1.2m Channel Master in Maidstone, title is incorrect, comes with azel mount & possibly an nprm but lnb holder is incomplete £29
https://www.ebay.co.uk/itm/224059166492
1.8m Primesat in Tewkesbury, with azel & ground mount £99
https://www.ebay.co.uk/itm/114271916162
Those web addresses don't appear to work directly- they all come back with messages like that below - but with the actual listing showing here above that after I copied and pasted that message here!:
"Your search - - did not match any documents.
Suggestions:
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords."
Links work for me.
The 1.2m is a bargain. The stand alone is worth that. Too far for me though.
jeallen01 - Looks like you're pasting the whole url into the ebay search box? Copy only the item number from the end of the link if you want to do it that way.
nelson_b
Contributor
Works just fine either way for me .....
