I am in Viet Nam so I can see Inmarsat 4F1 and 4F2Where are you pointing to? Inmarsat 4F1 is at 143.5°E (below horizon).
4F2 is at 63.9°E, 4F4 (Alphasat) is at 24.85°E, and 3F5 is at 54.0°W.
Newer generation 5 (GX) satellites are at 62.6°E, 56.5°E, 28.0°W and 55.0°W, but I don't know how active these are in L-band.
I do not think so because the Bgan service is still availableThat satellite experienced a total loss of attitude control and has not in operation as of 17 February 2018.
Because these sites list only broadcasting-type satellites, generally.Then why does it not show up in any of the satellite listings??
Hello,The OP is in Vietnam so can probably see it
I am looking for the spectrum of BGAN networkHe is looking for one that was broadcasting satellite TV.
http://www.bgansatellite.com
I used spectrum analyzer of Agilent, it is very good one but I did not see the frequency spectrum of Inmarsat 4f1 at 143.5EWhat type of spectrum analyzer???? RF, or one of those cheap satellite/PC types???
A good RF stand alone spectrum analyzer with a range over 2 GHz and a noise floor of at least -120 dB should see the signals from that satellite if your pointing at the right one.
Hello,
I think that I need to use SDRPlay SDR Radios to connect the dish antenna by cable and install software on computer to see spectrum of Inmarsat
Did you do that?
We can not see the spectrum of satellite by spectrum analyzer directly right?
143.5E may not be active now, try looking at 178E as they may have changed over to that satellite, see Channel Hoppers post #15, follow the info on that web site.I used spectrum analyzer of Agilent, it is very good one but I did not see the frequency spectrum of Inmarsat 4f1 at 143.5E
