Nice one, thanks
Will have to find a bit if 2 inch pole and see if it's bodgable
I think you are possibly confusing two
separate things:
- the motor stub supports the
dish, so, as long as the clamp
on the dish that clamps onto the motor stub is large enough (and most are!), then that "issue" is actually a "non-issue".
however, the motor is clamped on your pole/mast (i.e. the one on the wall or the ground), and and
that depends on the clamp that comes with the motor itself - so, as long as
that will fit around a 1.5" mast (and most should, although a 1.5" mast/pole is rather small for anything larger than a motor and 80cm dish), then that is
possibly also a "non-issue".
Edited: OTOH, I don't think that the clamp on a Zone 2 dish would fit on a 2" stub, but maybe I misunderstood
@ozumo 's question!
