statalite
- SF8008
DiSEqC motor with 1m dish
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
- UK Midlands
Hi guys,
I just wanted to get you opinions on the holders pictured.
I have managed to acquire an 80cm Mix Digital dish which I am considering replacing my zone 2 (which has 28.2e) so I can add 13e and 19.2e.
If I centre the dish on 19.2e, will lose signal on 28.2e even with the best alignment I can get?
I have attached a photo of the end of the dish arm, the attached images (the ones that are curved and seem to follow the arc) are advertised as Triax so not sure if the oblong part would fit as they have plastic that sticks out on a part you squeeze to add to a Triax arm, would this be a problem?
Would the "curved" options be better for signal gain provided they fit or the "straight" holder.
thanks.
thanks.
