a33
Specialised Contributor
- Sep 24, 2009
- Age
- 64
XSAT410
Rebox RE-9000
- The Netherlands
Hi. According to Dishpointer on my PC, I need a skew of 10.2 whereas the app on my phone says 17.7. The difference is 7.5 which google tells me is the pre-skew on the Astra satellites. But what google hasn't so far told me is which one do I go with when installing my LNB - Dishpointer or the phone app? My thanks if you can help me out.
In this case, you follow dishpointer.
The easy test: enter 28E as your longitude, in the calculator. If the skew-value is then zero, no pre-skew is accounted for.
In this case the skew from dishpointer says skew=7,3 (I used 28E instead of 28.2E), so the pre-skew is included.
Don't think dishpointer is right always, though!
All the eutelsat satellites (such as 13E) seem to have a pre-skew of 3.535 degrees, according to some rather official looking documents, but I don't think many skew calculators take that into account.
The satlex calculator indicates the included and excluded preskew skew value for the astra satellites (as "special case"), so that you can see what value to use...
Greetz,
A33
