- UK
All clear here (80cm dish badly pointed), though you will find you need upwards of a 1.2m even in Southern Norway
Receiver analyser
Sportitalia is now even broadcasting in HD... I guess it has enough revenues to continu broadcasting FTA (and in HD) over the Italian terrestrial network. That's the only reason they are on 9 east.I was surprised that Sport Italia is only available now to a much smaller audience on the 9 east Italian footprint with very much reduced advertising revenues maybe it will return to 13 east ?
Italia 2 and sportitalia dissapeared on 12606 V
I Guess this is the beginning of the end of FTA Italian multistream channels on 5 West... Other channels will follow and cease broadcasting on 5 West.I was surprised that Sport Italia is only available now to a much smaller audience on the 9 east Italian footprint with very much reduced advertising revenues maybe it will return to 13 east ?
Hi Galway,All 5WB transponders being received at Galway West of Ireland. I have noticed the quality level has increased a little at night on the MS frequency 11.509 (using 1.25 Gilbertino Inverto Quad Ultra LNB
Hi Galway,
Someone try to install a 90cm satellite dish for Fransat but he said to me that he can't get the signal.
I live near Clonakilty. I wonder if it is so hard to point the dish.
Any help would be very much appreciated
Hi Galway,
Fair enough thank you for this answer will move to Astra.Unlike Eutelsat 5WA which had massive signals all over Europe Eute 5WB has more tightly focussed beams. Up here in Southern Scotland 5W is barely worth bothering with nowadays even on a 1m dish. I'd say the beam or the signals have been tweaked since I last looked as Ive lost most of the signals. About the only frequency Im getting signals on are 11480H 3215 which carries French radio channels and is spectacularly uninteresting!
Hello Williams, it's sure; it will be more difficult to find a good signal on the 5WB but a lot of people living far from the edge still receive enough the MIS channels (for ex, member V_allejandro has a 120 cm in Sweden)As already mentioned in this thread the Transalpine has a very high fade at the edge of the footprint so even a 180 cm dish will not find this signal.View attachment 132770
