Forum upgraded to xenforo 2.2
I know. But Alt+S is still my first instinct.
Thanks for the changes to xenforo 2.2 Chris,
All working OK here now with file uploading & downloading :Y
TJExcalibur
Out of this world.
Southern England
Looks great to me.
Laser
IPad is now full of ads which were not there before. Delete them and they come straight back!
Laser
Thanks Chris for all your hard work!
The sliding thread index has gone. :Y
On mobile the floating menu bar that stays at the top of the page robs already limited screen space, with no real benefit.
Removing the animations has made a world of difference :Y
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Is the update for security reasons? If not I preferred the front end of the previous version.
If you were quick you will have downloaded my channel list for the SX88+ as it has gone for now while Chris fixes all the issues with xenforo 2.2
On the bottom of the page click where it says 'vice 2.2', then choose SatsUK fixed or wide to make it look like the ol' times :Y
sonnetpete
wordpress.com
Normandy, France
It's working fine here on an old version of Opera, running on Windows 8.1 I've even lost the adverts....
Mod. Note Shifted from a different Topic - hence the reference at line one to "this thread"
TBH, not about this thread but about the @chris changes to the forum today because - at least for me! - some of the most recent threads appear to have totally disappeared unless I click on alert emails that appeared in my PC's email Inbox!
Only if I click on those to view them, can I actually see the content (such as the above one from @a33) because if I then try to view "New Posts" then they are not there - NOR is the "Administration" thread in which IIRC @chris posted that he had updated the forum earlier!
Edited: Frankly, this is "a bit chaotic" as some new posts are appearing in "New Posts" whilst others are not, and that includes this reply that I posted in this particular thread after I posted this "Edited" comment! o_O
THUS, and in particular, @chris needs to warn us beforehand that he is planning to do major forum updates BEFORE he actually does them!
Problems with jpeg files not being seen now.
I can see them in edit but nobody else can,
You fixed this yesterday Chris/Admin so please fix again.
Just managed to re-insert some images on a post by Spiff, they are there, just need re-inserting, bit of a pain if it has to be done on all older posts though
chris
TalkTalk TV
Worksop UK
I've just installed a fix for the attachments not showing, please let me know if this has also worked on the jpeg images.
@chris I rather like the "Vice 2.2" Style :D
Sorted now with the latest fix by Chris/Admin
jpeg (Zip & RAR files can now be seen & downloaded by all members) :) :Y
Thanks, Chris
chris
TalkTalk TV
Worksop UK
That's great, thanks for checking. I will now continue with the other gremlins.
suspicious gremlins GIF by Cheezburger
