Just Sharing This Kabelio ag tv now fta @ 13 east
ben23
hotbird 13e, astra 19e, eutelsat 9e, eutelsat 33e
Switzerland
Unfortunately it's only 720p
astra19
98cm motorised technomate. 50e to 34.5w
Europe
I saw it while it was free to air briefly. The quality wasn't amazing and certainly didn't feel HD. More like good SD.
I will be intersted to see whats required if anyone tries activating this. Im guessing some sort of Swiss tax code, as no way this will be allowed to be activated by UK expat Fred Bloggs living in Cyprus or wherever.
dvdfilm
1.5m dish
spain
Probably a good VPN for the bbc IPlayer is cheaper and with better picture quality than Kabelio.
4Himdj
1.2 Laminas Dish
Rome
I'll let you know in a couple of days
I've received it unactivated through an international seller and it needs to be activated
regards
ben23
Switzerland
The Provider says that the picture quality for BBC/ITV will improve, they are facing technical problems at the moment:
"At the moment we cannot tinker with the system. The BBC1,2, ITV source is not "clean" at the moment, because about 2 weeks ago our glass SAT-IF converter broke and the source we are currently using has already been transcoded. If everything goes well, we will soon be able to use the live signal from 28 ° E again, which will add more sharpness. But we can also do a test with 1080i in November. We're open to that."
Adam792
Cheltenham
How come they’ve started a second transponder carrying the SRG channels? I thought they were supposed to be using simulcrypt on the existing versions on 10971H/11526H.
dvdfilm
1.5m dish
spain
So if they’re not using the satellite signal, are they using an Iptv feed right now?
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
Kabelio will be using SSR-SRG transmitter with the SSR-SRG on Hotbird to simulcrypts, unfortunately it was not possible for this to be completed by tomorrow. Unfortunately, SRG and Kabelio cannot do anything about that. In order not to endanger the start of Kabelio, Kabelio now has the 7 SSR-SRG transmitters on air twice until the Simulcrypt runs on the SSR-SRG TPs. Then the 2nd TP is switched off.
ben23
Switzerland
The provider says that BBC and ITV channels are now transmitted in Full HD 1080i
dvdfilm
1.5m dish
spain
Is there any feedback on this service yet? How is picture quality?
astra19
Europe
Has anybody set up Kabelio service successfully yet?
isr2002
1.15m, VU Duo4K
RO
Hi.
I just received Kabelio CAM from Amazon.
I bought it with the thought that a relative (who lives in Switzerland) of a friend will activate it. But when my friend asked his relative, she refused :) . Because was affraid not to pay something. Now, she's an old lady, I understand the the refusal.
May I activate the CAM with a random Swiss address taken from internet?
LE: I activate it.
After that, the CI module updated his firmware, than, unfortunately, a message appair: "For ussing PVR please save de PIN CICAM number". But the message disappear very quickly and I don't see the number. I tried 1111, 0000, 1234. No way.
Does anybody knows the pin?
novice44
Tecnomate 5400 CI
Xdome HD-1000NC
Hi.
LE: I activate it.
Hi
how did you find a Swiss address to activate the cam. Did you just google to find a random address? Is it just an address that is needed?
I have just ordered a cam and now I got to figure out how to activate it!!
Adam792
Cheltenham
Looks like the Kabelio Panaccess CA (0x4afc) has been added to the channels on both of the original SRG-SSR transponders now, so these should now theoretically clear with the card (10971H/11526H). The temporary 10853H Kabelio versions will presumably be switched off at some point following this.
The channels on 11526H (RSI La 1, RSI La 2, SRF Info and Swiss radio) are also set to be added to 10971H by the end of this month, with 11526H being switched off later in the year.
Edit: Sure enough, on the Kabelio website now they only mention 10971H and 11526H as the frequencies for SRG channels, with no mention of 10853H - TECHNOLOGY & SUPPORT :: Kabelio AG
astra19
Europe
Flysat is reporting Kabelio has added a few more UK channels. Can anyone confirm?
