- OP Gibertini 100 XP+ Inverto Black Ultra Lnb
- Epping Forest Essex
Blind Scan guide for H.265 HEVC HD satellite receivers such as the Octagon SX88+ & the Edision primo IP S2,
Blind Scan
Delete dead transponders on the satellite you are about to Blind Scan
Now Blind Scan the Satellite for example Eutelsat 10A @ 10 east
The Blind Scan will pick up all transponders from 10 east & 9 east
So I do a FTA TV only Blind Scan
You can then view the FTA TV channels,
Switch the receiver to standby for 20 sec
Now Manual Scan for encrypted transponders in the data base
Tick the transponders not scanned in the FTA mode,
Now add the code if known for the other transponders to view,
Save your channel list & other data to a USB stick
The data collected from the SX88+ can also be used on the Edision primo as the channel lists on these receivers is the same format,
Then you can have a channel list starting at 53 east to 34.5 west in sequence as I have on the SX88+,
The Edision primo has Astra 19.2 east 1st followed by Hotbird 13 east then the rest of the satellites,
I was not keen on this so was able to change this using the SX88+ Channel List.
Blind Scan
