Advice Needed Push-on F-Connectors
Afternoon
Does anyone know where I can get some more of the specific type of push-on F-Connector shown below as I need some for patch leads but I have been unable to track any down any like this one (which I think I got from a dealer 5 yrs ago when I got a Supreme Dark Motor swapped for the Superior version)?
(All I can seem to find are the cheap ones which "open out" and become a loose fit after a few connections/disconnections - but the one below is much more robustly constructed and hasn't done that).
Thanks in advance.
TJExcalibur
Out of this world.
Southern England
CPC. Look on Google. Good prices and delivery.
Ah but now I've found them = "Vision V17-004"!!
That was after I found out that P/N (on the TradeWorks site - for £49.50 +VAT EACH!!) and then I tracked them down at CPC-Farnell at 65p each inc VAT, and will get some next time I place an order with them.
Yup, that's where I looked first after I found the P/N - but it was very difficult to find that P/N until I searched a couple of trade-sites that I have used from time to time. Only bug-bear is that an order needs to be £17.50 exc VAT before you get free P&P - and that would mean ordering something like 30 of them, so I'll wait until my next order and add them to that!
I have a few here if required (they have a spring type clamp with three or four windings to keep the end attached)
Or
If you require more than a few then go for a push on earth bar from an existing 8, 12, 16 or 32 way distribution amplifier.
et voila. Free washers and a bit of metal, gratis.
Well, as you've seen the current "patch panel" setup, you know that I drilled a lot of holes in the lower edge of the desktop, and fitted all the cables through it and put female F-connectors on the outer ends. Frankly, that's "good enough" for me since I don't need/want to go through that process again to fit those earth-bonding multiway bars , and so I'll settle for getting better male-connectors for the external patch cables.
BTW: the connectors to which you linked look pretty similar to the Vision ones - but are about 50% more expensive, and so I'll wait until it's time for the next CPC order and then get some of the Vision ones.
