Free to collect
Pipedream
Sheffield
Need to make space in the garage so anyone willing to collect from the Sheffield area can have.
1.5 Irte with ground mount
1.8 PF channel master
90cm channel master (ku band)
I think there are 4 to 5 1.2 channel masters
Anyone interested send me a PM
Pipedream
Sheffield
The 1.8 channel master and a 1.2 channel master have gone.
I thought Sheffield was in lockdown ......
Pipedream
Sheffield
It,s on tier 3, that might all change in the next few minutes when the new announcement is made.
kemik8066
Looking for a large around 1.2 - 1.8m prime focus satellite dish has to have no warping or dents. Thanks guys.
London
Hey mate, is this still available??!! Thanks Kim
Pipedream
Sheffield
kemik8066
London
Perfect, thanks I’d love to collect the PF Channel master from you. I’d be travelling from London next week in a large van of that’s ok?. How is the condition etc.. any dents or warp issues? Regard Kim
kemik8066
London
Not sure how to DM you contact details Pipedream. Also the other Channel Masters you have, are they PF? Might be interested in them also. Kind Regards, and thank you Kim
Pipedream
Sheffield
It's the 1.5 Irte I have left, this is a PF dish. The 1.2 channel masters are off set dishes.
kemik8066
London
Aaah ok. Not familiar with the Irte, is it a similar parabolic like the Channel Master? also how is the condition, Any dents warps etc? We could connect via What’s App if that’s easier for you. 07830 xxxxxx
(Mobile number removed for -everybody's - safety)
Pipedream
Sheffield
Kemik8066 please see attached pictures of the 1.5 IrteIMG_0066.JPGIMG_0067.JPGIMG_0068.JPG
kemik8066
London
Thanks mate, in your opinion, does it look like it’s in good condition? No dinks, dents, warps etc? I’ll pop down for it for sure. Thanks
kemik8066
London
So I’m planing on heading up a few hours closer to you tomorrow for work and I’ll be able to head up either Tuesday or Wednesday. Can you let me know your address? Possibly your number. Also if you think the dish is in good enough condition. I cannot tell from the photos alone :). Thanks Kim 07830xxxxxx
Mod.Note Phone number redacted for the safety and security of everyone.
You may now have sufficient Posts to avail yourself of the Conversations (Private Messages) facility.
Do check. If not now auto-enabled a handful more Posts should do it.
With IRTE dishes, it is not adviseable to put them on the roof rack for longish journeys since they will bend like a banana at motorway speeds (personal experience).
A 1.5m will not fit in a standard estate car, I recall Pipedream was using a pickup type vehicle with the sheep-dip jacuzzi at the rear, but a small van is your minimum style jalopy for transportng such a reflector.
Also, take a flat piece of board around 1.6m square with some cardboard to protect the rim, and don't throw anything else , (like tools/dog/the wife) in the back.
The pictures sent show it is in fine condition for its age, though being a photographer, you could do better than I can with the laptop imagery.
IRTE dishes are a panel beater's dream if you do put any dings in the aluminium. If you do dent it then I could get it back into shape, or provide an alternative model as a swopout.
kemik8066
London
Perfect, Channel hopper :) sounds great. I’m planning to collect In my LWB Ford sprinter Van. It’s larger enough for ten plus the wife haha I believe so I should be good however I’ll be glad to swap out with you if it need some attention. Again, thanks for all your help.
Ah, if it's one of those, lie flat/face down on the floor with the piece of wood underneath.
kemik8066
London
Great I’ll try that :)
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
is that IRTE the same material as the 1.2m version?
