11,0° East Inmarsat GX 5
dreamsat
germany
Hello, i can receive two transponders. The 20392 is verry strong.
regards
dreamsat
germany
spectrum in LHCP and RHCP KA-Band B
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Circular left spectrum from my place.
dreamsat
germany
these should possibly be RHCP. you can't check this. or your dielectric is not installed correctly
? - did you use your Saorsat lnbf to look at this - if yours is the same as mine then the lnb supply voltage is opposite to what we normally use for pol switching. So Saorsat at 18v gives RHC and 13v gives LHC. It fooled me before i read the whole spec for the lnb :Y
dreamsat
germany
If my depolarizer is set correctly, I cannot see the R plane. please check again
i work with Gilat and Depolarizer
dx qwer
Rastatt/Germany
It´s an "Orbital LNB1825F-1000D-WF55" in my scan with plastic plate inside (probably not perfect matched...)
dreamsat
germany
it's a shame that the exact coordination didn't work. this only makes it more difficult for other users to find the right settings. if i'm not sure then i turn away a strong transponder with the depolarizer and try the other level. so I'm relatively sure.
dx qwer
Rastatt/Germany
... if I see it correctly, it is only the 19811. :rolleyes:
dreamsat
germany
have you tried R. only then can you be sure. the transponders above have a different beam. I don't get them here.
dx qwer
Rastatt/Germany
Circular right scan. So (it seems that) 19811 is from (strong signal in) circular right polarity (in my previuos scan above):
19811 R 45000
Bilder​
dreamsat
germany
For R, your dielectric now seems to be perfectly rotated:Y
.. just keeping an eye on this @ 11° E 20.535 H.
dreamsat
germany
it is from Sicral 1 B at 11,7° East, even if it says 11 °
for me it's vertical
vg
dreamsat
germany
Scan LHCP and RHCP in Band B
dreamsat
germany
10325 LHCP 20000 in Band C
dreamsat
germany
new transponder at 20392 LHCP 25000
dreamsat
germany
my scan
dreamsat
germany
my currend scan
dreamsat
germany
new is 19312 L 45000
