Eutelsat Hot Bird New satellites in 2021/2022
Launch of the Eutelsat Hot Bird 13G satellite in 2022
The new telecommunications satellite Eutelsat Hot Bird 13G from the French satellite operator Eutelsat will not be launched until the first half of next year. So far, the launch of a new satellite was planned for the second half of this year.
Eutelsat Hot Bird satellites 13G will replace the existing series Hot Bird position at 13 ° E
Earlier, the Eutelsat Hot Bird 13F satellite will enter space, with the second half of 2021 still expected.
Both Eutelsat Hot Bird 13F and Eutelsat Hot Bird 13G will operate at 13 ° E and provide television and radio broadcasting capacity in Europe and the MENA (Middle East and North Africa) region. Both satellites will provide 80 transponders in the Ku band (73 in the equivalent of 36 MHz units). The total number of transponders will not change with the new satellites - 102. 95 transponders in the equivalent of 36 MHz units will operate in the band.
Hotbirds 13F & 13G update
Launch 30-Sep-2021 (Estimated)
Guiana Space Centre
Ariane 64
Risky using what will be a fairly unproved rocket. Ariane 6 hasnt flown yet.
we hope not be hotbird 7 fall down
before meny year ago
Only one new Hotbird this year
Hot Bird 13F 13° East 30 September 2021 Ariane 64 Kourou ELA-4 80 Ku
This will allow a couple of the other satellites to move to new position.
Hot Bird 13G 13° East Q2 2022 Ariane 64 Kourou ELA-4 80 Ku
Launch id will probably be changed.
both launch on ariane 6
and eutelsat no report of new footprint eirp
Mid-December or 2022 q1
What are you referring to ? Hotbird 13G or Hotbird 13F ?
Can you please supply some links Solly ?
6.18 Regarding the GSAT-24 satellite, the Indian Administration had initially wanted to use an indigenous launch vehicle, but had been unable to do so because of the COVID-19 pandemic. It had therefore turned to a foreign launch service provider, Arianespace, and had obtained a confirmed launch window in November–December 2021. It nevertheless requested an 18-month extension for bringing into use the frequency assignments of the INSAT-KUP-BSS(83E) satellite network, to 7 August 2022, in order to build a sufficient margin for contingencies into the launch schedule and not to have to submit another request for an extension to the Board.
This thread is about Hotbird not GSat24 maybe it is posted elsewhere ?
I do not see the connection can you advise please Solly.
hello william
i we need to check gast 24 and hotbird if it true launch or september this year or delay to november
for now ses 17 maybe will be launch on september let see
Ariane 5 ECA | Hotbird 13F & GSAT 24
Arianespace | FRA
Kourou, French Guiana
April 30, 2022, 3 a.m.
it plan end april or first may 2022
new date launch july 2022
