s-band
Essex
Sold £46.89p, a bargain for someone looking for a C-Band dish, was it bought by a forum member, hands up !
Nicknamed "The Tin Dish" on the forum, the 2.4m Fortec Star performed reasonably well in C-Band based on observations from a few forum members, "aceb" and "s-band" spring to mind.
That looks like my old one. I guess the seller is using the stand for his new dish.
Joolz
1m Astro 55°E - 63°W
Pretty sure I have one of these dishes in the garage. No idea what to do with it though...
Potentially a cheap actuator in Shrewsbury, with what looks like a couple of Satellite Superstore how-to VHS.
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
nice little bargain there and cheap,great dish.
Having a Sharp LNB probably means it's not been used for "years" - BTW, nothing at all against Sharp LNB's as I bought several a decade or so ago and they were very good, but it does tend to indicate that the system may not have been "put through its paces" for "some time"
OTOH, might be a very good buy, albeit with some work needed to get it fully up and running properly.
butchyboy
ireland
Did she looks mint,and a new lnb won't break the bank.
Mount needs some TLC,it's a bargain probably be got for 20 quid
Wasn't thinking of replacement of the LNB - more likely the actuator.
butchyboy
ireland
cheap as chips that cm set up.
The stand alone is worth more than that...
Manikm909
Small'ish Dish Man
Kent, UK
if you want rid of it, you sell stuff cheap! no one buys satellite dishes except us geeks
Manikm909
Small'ish Dish Man
Kent, UK
check out this beast:
Manikm909
Small'ish Dish Man
Kent, UK
i wonder if it would run on a diseq motor?
butchyboy
ireland
its stuck on a fixed mount,would be some high price for a polarmount for that dish.
also transportation cost etc
