Advice Needed 40.5W c-band ?.
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
hi guys anyone in the uk or ireland receving channels on c band on 40.5w ?
also anyone getting espn brasil or foxsports on 40.5 w?.
butchyboy
ireland
Very interesting.
Is there any ku band channels on 40.5w so I can know for sure I'm on 40.5w before I take off my ku lnb and put on my c band lnb to try get channels
Yes, I receive about 140 odd channels on C Band with a 1.8m dish in the UK. Nothing on Ku as the footprint is aimed at South America/Brazil.
mikeisyou
Feed Hunter
England
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
There are Data TP in the Ku band .. need to receive a TBS card..
Very interesting.
With a device that reads and lock the signal for transponders with generic stream,you can locate the 40.5 W position, a signal that is strong enough to be detected by a 1.10 m dish,especially in your area,which is favored.
Below you have the spectrum with active transponders atm.
butchyboy
ireland
unfortunately guys i do not have a pci sat card,so im kind of wondering how am i going to locate 40.5w on c-band
Manually input transponder 3920 R(V), SR 20000 into your satellite receiver and use that as a marker to check with the receiver signal level indicator.
It was one of the strongest transponders on 40.5 West last time I checked it.
You could also use 3887 L(H), SR 4190 as a marker, It is a T2-M1 transponder but should show up in the signal level indicator bar on a non T2-M1 receiver.
This one was quite strong last time I checked.
You can use dishpointer to get an approximate idea where the satellite is with reference to your locality.
butchyboy
ireland
i will be using a dr hd f15 box.
A Dr HD F15 receiver will show T2-M1 frequencies in the signal level indicator bar. I used one of those receivers when I created the table I uploaded to the topic linked to below.
It will not be able to lock the T2-M1 signal but it will allow you to use it as a marker.
Post 106 of this topic contains the signal level table I created for 40.5W C-Band Using a Dr HD F15 receiver
Using F15, and this table, you can even get quality levels, though it will mostly stay red (unlocked). But it's a very handy feature.
Any DVB-S/S2 QPSK/8PSK modulated frequencies can be used.
butchyboy
ireland
cheers guys.
but im still wondering is it worth me trying 40.5w because im afer espn brasil and foxsports on a 1.8m offset dish in the southeast of ireland.
anyone with a similar size dish in the uk picking these channels up?,and will the stay locked 24/7 weather permitting etc or is it just a certain time of day you can lock them?.
cheers guys.
(Christine.........)
With the 1.8m well-tuned antenna you have a good chance of receiving the two sports packs.
Look at the SES-6 cover map on your area:40dWB
butchyboy
ireland
thanks satesco and im very south here in ireland am well inside the 40dWB
frankviana
Satellites/tv
Brazil
Here, my Edision OS Mini 4k (received this week), working fine SES 6 native T2-MI:
Frank
mikeisyou
Feed Hunter
England
Could someone advise on what signal quality they are getting from 3710 L 8330 and 3980 L 21600 on 40.5w please.
Last time I measured 3980L, SR 21600 I was getting 9.1db but it was a couple of years ago.
However, I think as it is an ESPN broadcast frequency the dB level might be fairly constant.
