DISEqc motors
moonraker 1
1 meter ali dish tecnomate motor technomate fta rx pc desk top
salisbury wilts
My ten year old technomate 2200 suffers from over or under run please can can anyone recommend a replacement and what the difference between the technomate 2300 and 2600 thank you
Is there a backlash adjustment on the TM2200 ?
moonraker 1
salisbury wilts
yes there is backlash on the tm 2200
An adjustment screw, on other models it is under the four bolt plate.
There may also be play in the main shaft bolt, other forums mention shimming with thin plates of steel.
Manikm909
Small'ish Dish Man
Kent, UK
Dark Motor or TM2600
moonraker 1
salisbury wilts
Has improved thank
