Kti h180 proform
Your translator is fine, good video
anto@
italy
original + clone
Terrible (the post is the wrong diameter) :-wow:D
anto@
italy
unfortunately I have the walled 2.5-inch pole
and for the moment I do not want to replace it
so I decided to make a small clone
the disc is a gibertini of 150
in the future something bigger
regards
anto@
italy
anto@
italy
add
The declination motor might be OK for the 1.5m, but since it is always in 'stretch' mode, I would not expect it to last with a 2.7m Laminas reflector on the front.
anto@
italy
anto@
italy
good evening
after a year I took my KTI h180 proform out of the box to do some empty tests
I made some current measurements to know the power used by the motor, with my instrument (amperometric clamp for continuous currents) I read a value of about 0.85 Ampere over the entire polar arc, could someone here make similar measurements?
in this way I can understand if my engine works well !!
it has never been used with a parable
just a quick test with a prodellin then dismantled everything and put it back in the box
thank you
1 Amp or less is very good. Just bolt it to the dish and try moving across the arc.
anto@
italy
good evening today I did some tests first empty then with a weight placed in front and a counterweight placed behind I have optimized the current consumption over the entire polar arc now I have an absorption ranging from 0.48 to 0.70 mA in the photo you can see a weight that simulates the weight of a parabola of about 15 KG
I'm always waiting for someone who can measure with a similar engine to make a comparison thank you
Counterweights are always the third best way to go.
Always reduce weight front and rear , second best.
Retaining rigidity for the parabola is #1.
anto@
italy
now on my system I have this configuration
smr 1224 gibertini 150 + rotor feed and counterweight behind
motor absorption 0.50 A
anto@
italy
I don't like the black color of the KTI, today I paint it all in white, I really like this color
Bravo ! Down to the last few grammes as well.
That is how a proper satellite mount should function.
(saving the environment, one step at time).
anto@
italy
thank you
modification made today
anto@
italy
after three years of waiting and testing I finally replaced my old smr 1224 system with declination motor and feed rotor with my new satellite system
laminas 180 and Kti hh proform, with declination motor
Great job, now you have time to replace the broken tiles ;).
anto@
italy
thank you very much
