butchyboy
- channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
- ireland
any one have details on this dish?,all i know i think it was polish made.
the offset angle postion of the focal point and the lnb,s aiming point on the surface of the dish?.
i always taught you aimed the lnb to the dish centre,but rimnants says no not at all.
so where would be the best part on the dish surface to aim the lnb weather its ku lnb or cu lnb.
- I edited it but you read the first version
