16°E Eutelsat 16
dreamsat
germany
21565 H 2754 3/4 "DTV 1-4"
regards dreamsat
regards dreamsat
Nice one, just can't get a lock on it here with 7dB / 1.25 Gibby / Inverto Ka-Ku lnbf.
Are you using the 2.2 for this signal
dreamsat
germany
Yes 2,20m, but my adaptation is not 100%
regards
dreamsat
germany
current scan
regards dreamsat
My effort today. Unusual for me to get full lock on every TP scanned in.
Gibby 1.2 with Inverto KaKu LNB.
dreamsat
germany
21578 H 1100 2/3
21580 H 1124 3/4
dreamsat
germany
my scan with MCL-KP04 PLL LNB (",20m)
dreamsat
germany
the 21564 H 127 I must with hardlock:rolleyes:
dreamsat
germany
Scan from this afternoon with 2,20m
regards
dreamsat
germany
21624 H 20662
dreamsat
germany
it's a shame that it doesn't work:rolleyes:
rodscha
Just a question:which receiver allows receiving the 21000 plus frequencies that seem to abound on 16E?
Such as 21624 H 20662
dreamsat
germany
You need the right LNB and then it should work. Unfortunately, I haven't had any receivers for a long time. There was always some problem. With the PC cards, it's all very easy and flexible.
rodscha
so i should connect my dish directly to some computer prog?
Or,which LNB should I get?
The thing is,my receiver won't take in anything above 12999 ( a comag FTA receiver)
dreamsat
germany
The LNB should cover the frequency range 21200-22000 Ghz. The Octagon Receiver should work. It could be possible that the receiver works with Linux software
rodscha
does the receiver (such as Octagon)work as plug-and-play or does it need to be "programmed" after puchase?
dreamsat
germany
Unfortunately, I can't answer that for you. I don't have a receiver. I only know people who have reception with Octagon KA-Band.
You can get it with a Technomate TM-5402 if you edit the L.O.
Same for quite a few receivers, all you need to do is to edit the L.O to match the LNB fitted to the dish and get scanning.
